Hope next plugin version take in account this problem :
viewtopic.php?f=33&t=64362&start=130#p331522
I need to revert back to 441 3064 to render image...
HDR problem
C. RAM Capacity (i.e. 6 GB)
This is not an issue,
just optimization for HDRI default,
you just need to set the intepretation manually to 32 bit float instead of the 16 bit float default in some case (high EV).
Isn't this setting available in the Max plugin ?
Pascal ANDRE
- paride4331
Hi Calus,calus wrote:This is not an issue,
not yet.
lol I realize now it's not either in the Maya plugin, only in Standalone.... so the plugins are late...paride4331 wrote:Hi Calus,calus wrote:This is not an issue,
not yet.
Pascal ANDRE
In max when you load the hdr you can change how it stored internally but don't change the render....
- paride4331
32 bit can make the difference:HHbomb wrote:In max when you load the hdr you can change how it stored internally but don't change the render....
viewtopic.php?f=9&t=64067&p=331040&hili ... nt#p326360
Using 16Bit can save memory and it works fine in most situations.
I mean for my case...
@Paride : Is there a problem with 443 vs 441 ? I can't have the same render with same scene.
- paride4331
Hi HHbomb,
4.41, 4.43 and 4.44 have the same 3070007 SDK, so there should not be any differences.
I do not know your scene and workflow with HDRI, so it's hard to answer. Would you give more info about it?
Hi Paride.
I send you a scene which render differently with 4.41 and 4.43. This is a hdr problem as with another hdr OR render identically with both 4.41 and 4.43.
But it is strange that renders are different with 4.41 vs 4.43. To re-render the scene I must switch to 4.41.
HDRI is from HDRIheaven https://hdrihaven.com/hdri/?c=clear&h=flower_road
- HDR.zip
- (161.65 KiB) Downloaded 218 times
- paride4331
HHbomb,
you're right, 4.41 and 4.44 work differently.
I tried exporting to SA, the issue is as follows:
4.41 has default input 32bit and 4.44 default input is 16bit.
My advice, waiting for Octane 3dsMax plugin 3.08 SDK (I think a handful of days), is to use 4.44, export to SA and switch to 32bit before render.
We absolutely need a 16/32bit RGB image option in Octane 3dsMax plugin.
I will make sure that developers do not forget it.
