Noise on edges of Shadow Passes
I can't check that detailed but you should check that in a compositing software after comping not in LV or PV. And search for similar topics with answers.
niestudio
see this thread viewtopic.php?f=30&t=56386&start=10#p301206
Black dots will not show when your shadow layer is underneath your object in compositing.
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
Hi colinleiker,
I suspect that you are experiencing the same issue reported innthis other discussion, and will be fixed in the next update of SDK:
viewtopic.php?f=30&t=61674#p315608
ciao beppe
Whispermode
Devs - please confirm: this is still a problem, even in 2019.1 XB2, right?
The residual internal noise will be covered by the beauty pass on top.
What is important is to have a clean result outside of the alpha of the Render layer, for shadows and reflections.
ciao Beppe
