Which feature do you need the most?
Region Render
139
6%
Network render
85
4%
Render Passes
239
11%
Hair&Fur
287
13%
Particles
229
10%
Multilight
156
7%
Internal Texture Mapping (planar, box, spherical, cylindrical, camera and so on)
88
4%
Undo
104
5%
Volumetric: fire, smoke, clouds
370
16%
Mixing of daylight and HDRI environment
213
9%
Subdivision surfaces (OpenSubDiv)
81
4%
Multi UV channels
129
6%
Rounded edges
131
6%
Total votes: 2251
Notiusweb
I'm thinking this is a small one, but who knows...
Can there be option in the Background image dialogue button to allow the image to override an Alpha-only export?
This way the image will be intact in the final render.
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
nuno1980
The water vapor (cloud, nebulosity, fog...) should have dispersion because we see halo (nebulosity very low opaced) but gases have (much) lower dispersion than liquid/solid.
Smoke, dust, brume... haven't dispersion due to the lack of humidity (= 100% dry), ;)
Currently OR cannot render "halo"... But halo support for v3.1 or v4?
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
Lewis
Hi!
Guys, can we get feature that Displacement node works with Projection node and with procedurals ?
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
Phantom107
What about the ability to draw a PNG background on top of the render view? Then it would be able to for example import an image that has the rule of third on it, that would help placing the cameras
Notiusweb
An ability to filter, by text, items in the Geometry Node list.
Give you a working list filtered by a text string, so you don't have to mouse up and down looking for a single item set amongst the whole entire mesh list.
Plugs: Enterprise
RealityFox
Simplified Skin shader. Something like what Renderman has, I learned how to make a decent skin shader but for newbies something simple and effective for skin would be great.
rajib
Dear Octane team,
An easier way to position the sun in the daylight environment would be most welcomed. Something that doesn't need me trying to locate where in the world the scene is supposed to be located or modify and set so many sliders to just try and get the sun to be where I need it to be. Just 2 sets of control. One how high or low the sun is on the horizon, and another that controls the direction of the sun with regards to the camera which can be a slider with 0 to 360 as value.
E.g. Direction of sun slider - 0/360 would place the sun behind the camera, 90 on the left of the scene, 180 on the back of the scene, and 270 on the right of the scene. Height of sun slider - 0 to 100, 0 would place it at horizon, 100 at the top. The two values will position the sun with regards to the camera.
Can something like that be implemented as a separate option from what is provided today ? Users of Octane can use either one they prefer - location and time based lighting (current) or just control that actual sun position by setting just 2 sliders.
Rajib
Windows 10 Pro i9-9980XE 128GB RAM|4 x Titan RTX
Houdini 18.5(2020.2.1.2)|Cinema C4D R26|Daz Studio Pro 4.21.0.5(Octane 2021.1.6.83)
NVIDIA 460.89 Studio Standard
PolderAnimation
Cryptomatte would be very nice to have.
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
Notiusweb
Can you add a check box that will say "2X Speed Multiplier", or something to that effect? I know it is silly and may not do anything as it is just text with a check box next to it, but I'm thinking maybe the program will believe it does do something and give us twice the speed?
I know, I know....why not then "10X Speed Multiplier"....Well, I just don't want to tip the program off. Just thinking something subtle enough to make it sound plausible...
Plugs: Enterprise
Notiusweb
How about "Extra Hot Pixel Removal"? For those stubborn hot pixels that still insist on being rendered no matter how much Hot Pixel removal you apply?
It would be nice to eliminate them!
Plugs: Enterprise
