OR since v3.00 is caustics later than v2.25 at same S/px
nuno1980
Hi, guys.
Dragon invisible test at resolution screen of 1002x602:
-- v3.01.1b:
-- v2.25:
I get caustics later using v3.00~v3.01.1b at same samples per pixel (S/px or spp). :? :(
PMC default settings except few things - see right of 1st image
Specular material for dragon default settings except:
- reflection and transmission 1.000
- índex of refraction 1.000
I hope the caustics will be better/earlier than v2.2x or this issue will be fixed to undo as v2.2x.
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
abstrax
Thanks for the report. We will look into it.
roeland
Can you upload the scene you're rendreing?
And also, what effect does this have on the scenes you're rendering? Usually, if an object like a window is supposed to be invisible or transparent to light rays (for instance windows) the material will have the "fake shadows" option enabled. If you see caustics in the scene from an object, this object will have an IOR different from 1, and usually you set the caustic blur in the kernel settings to a small value, like 0.01, so the caustic will be rendered faster (but slightly blurred).
Roeland
nuno1980
roeland wrote:Hi,
Roeland
Yes, download orbx -
dragon invisible.orbx
(32.35 MiB) Downloaded 526 times
Wedding glass test:
-- v2.25
wedding@1002x602 - daylight-08h@50diff+52spec-depth,10k-reject_151705 spp-7h56min.png
-- v3.01.1b
wedding@1002x602 - daylight-08h@50diff+52spec-depth,10k-reject_151705 spp-4h58min.png
PMC default settings except:
- 151705 spp
- 50-diffuse and 52-specular maxdepth
- 10k-reject
- parallelism 1
- caustic blur 0.000
v2.25 is better caustic = more realism than 3.01.1b (look 3rd ring on right) but v3.0x is ~2x faster than v2.25.
See caustics "cleaned" for v2.2x only. :)
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
I've edited to change 2nd image in OP. ;)
v2.25 at PMC kernel is normal. :)
I want unlimited samples per pixel in next release!! - I'm not worried despite long rendertime as days or as some weeks. I don't care animations but yes only few images about any scene. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
roeland
What is the result with a caustic blur setting of 0.001 or 0.01?
Roeland
nuno1980
roeland wrote:What is the result with a caustic blur setting of 0.001 or 0.01?
Roeland
I don't render, sorry but unfortunately, (very) hot weather during many days and it continues until saturday. Therefore, my room is 29 ºC in Porto (Portugal) and it was 31 ºC on yesterday.
--> Please you should fix PMC unoptimized (= appear caustics later) and increase from 256k to unlimited samples per pixel in next release after new v3.03.3 (the issue as my thread isn't listed yet).
Therefore, I keep to use v2.25. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
Wedding test - caustic blur 0.001:
-- v3.03.3
-- v2.25
v2.25 continues to be better and more visible caustic (3rd ring on right). I prefer v2.25 until the issue fixed. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
Look new 2 images
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
Ah... We get caustics later in v3.00~v3.03.3 due to maybe wrong number of rejects (10k). ;)
IMPORTANT! Do not forget to increase maximum spp from 256k to unlimited (as 0=zero) in next release with this issue fixed. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
