Octane vs. Arnold Glass Mat
zsdani
Despite the topic I don’t wanna to decide which renderer is the best, I’m only looking for answers. Also I think both of them are fantastic renderers over all and of course in it’s own way too.
I made a quick comparison and the main focus was on glass material. Both scene are identical with the most simple glass and (HDRi) render setup.
But I didn’t understand what causes the significal differences. As I see from Octane side there is missing glossy reflections and again I dont’ know why. I hope so the experienced users of this forum can give me a reasonable explonation. Thanks.
Hi zsdani,
What are your kernel and specular material settings?
Could you share the c4d scene in order to compare the results?
ciao beppe
zsdani
Of course I can. Sorry the kernel I used was Path Tracing.
Here it is: http://1drv.ms/1QXCKL0
nuno1980
Change kernel from path tracing to PMC and increase both diffuse and glossy maxdepth to 20.
What's your videocard?
PS: If you deserve "nature" then any specular material has ALWAYS dispersion. ;)
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
zsdani
I did it, here is my result. I think it's pretty much the same as before with the Path Tracing kernel.
Sorry for the noise. My gpu is an old GTX 460 OC with 1 GB ram.
nuno1980
No dispersion?!
Caustics at PT
i7-12700KF
32GB DDR4@3600
Hi zsdani,
in c4dOctane, never load directly an HDR in the texture node:
but, always use an Imagetexture node before loading th HDR, in this way you have a better control on the Gamma and the illumination values are correctly transfered to Octane. Here is your scene with gamma at 1:
there is also a shortcut button that automatically loads the Imagetexture node ;)
ciao beppe
