Improved batch render script
Forums: Improved batch render script
Re: Improved batch render script
Postby knot515 » Sat May 30, 2015 8:25 pm
knot515 Sat May 30, 2015 8:25 pm
This thing it's so helpfull than you!
i'm doing a pretty long video next week and i'm testing workflows right now. This script will help a lot!
But there's one thing, maybe you can help me. In my workflow i use animated cameras exported from Max. My problem is that if i export cameras with different frame count the animation slider shows only the longest one even if i select the render target with the shorter frame count pinned into.
That's an example test. I have 2 cameras, one with a 237 frames animation and one with a 50 frames animation. The number that i see on the frame slider it's 237 with both render target. If i render this setup with the script in this post i get 237 frames for each animation.
if i delete the 237 frames camera the animation slider goes back to 50 frames.
knot515
Postby r-username » Wed Jul 08, 2015 2:38 pm
r-username Wed Jul 08, 2015 2:38 pm
When I import .exr files into fusion (vfx composting soft) I noticed that the batch render saved .exr files are different (lighter/darker) that files saved tonemapped using the drop down menu. It appears to be gamma related.
or is just an issue with fusion reading file headers or metadata differently?
i7 960 - W7x64 - 12 GB - 2x GTX 780ti
http://www.startsimple.com/ - http://www.gigavr.com/
r-username
Postby vinz » Fri Oct 02, 2015 5:09 am
vinz Fri Oct 02, 2015 5:09 am
Great ! thanks you ...
but still missing the number of "0" feature that we need before frame number.
having :
Frame_001
Frame_002
then ...
Frame_009
Frame_010
then ...
Frame_099
Frame_100
etc...
would avoid mass files renaming.
i7 8700k / 16Gib / GTX980Ti 6GiB / win10x64 1803 / Blender 2.78a / drivers 416.34 + Octane 4.0 Standalone / OctaneBlender
vinz
Postby stratified » Fri Oct 02, 2015 6:51 pm
stratified Fri Oct 02, 2015 6:51 pm
r-username wrote:When I import .exr files into fusion (vfx composting soft) I noticed that the batch render saved .exr files are different (lighter/darker) that files saved tonemapped using the drop down menu. It appears to be gamma related.
IIRC, the batch render script saves the files in linear color space which translate to tonemap curve linear and gamma of 1. If you save the file as tonemapped EXR via the dropdown, it will apply the gamma and tonemap curve configured in the imager node.
cheers,
Thomas
stratified
Postby stratified » Fri Oct 02, 2015 6:52 pm
stratified Fri Oct 02, 2015 6:52 pm
vinz wrote:Great ! thanks you ...
having :
Frame_001
Frame_002
then ...
Frame_009
Frame_010
then ...
Frame_099
Frame_100
etc...
Ok makes sense, we will change it in the script that ships with Octane.
cheers,
Thomas
stratified
Postby vinz » Fri Oct 02, 2015 7:08 pm
vinz Fri Oct 02, 2015 7:08 pm
stratified wrote:Ok makes sense, we will change it in the script that ships with Octane.
Many Thanks Thomas :D
vinz
Postby LuvMultimedia » Tue Oct 20, 2015 6:35 pm
LuvMultimedia Tue Oct 20, 2015 6:35 pm
stratified wrote:Hi all,
I've spent some time combining the batch render script with the render animation script. This script will ship with the next release of the standalone. We already want to put it out here so you can already use it and help us find some bugs ;)
The attachment batch-render.png is no longer available
The attachment batch-rendering.lua is no longer available
thanks,
Thomas
Hi, I am having an issue with the script. For some reason it won't number the frames -- instead it keeps writing the frames over and over again , example, instead of going mirrors 1, mirrors 2, mirrors 3 --it just writes mirrors. I am sure I set everything up right --here's a screenshot of the work...
WIN 10 64 | Geforce 970| 16 GB
LuvMultimedia
Postby vinz » Tue Oct 20, 2015 6:44 pm
vinz Tue Oct 20, 2015 6:44 pm
LuvMultimedia wrote:Hi, I am having an issue with the script. For some reason it won't number the frames -- instead it keeps writing the frames over and over again , example, instead of going mirrors 1, mirrors 2, mirrors 3 --it just writes mirrors. I am sure I set everything up right --here's a screenshot of the work...
Hi Luv, to add frame number you need to add the "%f" switch after your filename in the template
in your exemple this should be : mirrors%f%e
etc... the switches are listed in the popup.
Vincent.
vinz
Previous
Return to Lua Scripting
Wed Jan 20, 2021 7:41 am [ UTC ]
