@aggiechase37: It's to do with scale, increase Ray Epsilon.
cheers
brasc
Version 2.23.2 - R6.2 (15.07.2015) - Obsolete stable
- aggiechase37
That was it. Thanks so much!brasco wrote:@aggiechase37: It's to do with scale, increase Ray Epsilon.
cheers
brasc
Chase
Win 10 - Intel 4770 - 2x Nvidia 1070 - 32 gigs RAM - C4D r16
http://www.luxemediaproductions.com
- connartist
There's probably a reason this is not default, but is there any way to duplicate a connection of nodes in the node editor and maintain all the connections? Right now I'm trying to duplicate a mix material 12 times and Im having to duplicate, then reconnect the structure before making my changes. Thanks!
It's not supported. You have to do connect by hand. Maybe for next releases.connartist wrote:There's probably a reason this is not default, but is there any way to duplicate a connection of nodes in the node editor and maintain all the connections? Right now I'm trying to duplicate a mix material 12 times and Im having to duplicate, then reconnect the structure before making my changes. Thanks!
in R6.2 in PT-mode specular depth and glossy depth are called different in LV-settings and in Render Settings / overwrite kernel Settings. that shoud be the same name right?
Go out of node editor. Select mix material with all materials connected to it.connartist wrote:There's probably a reason this is not default, but is there any way to duplicate a connection of nodes in the node editor and maintain all the connections? Right now I'm trying to duplicate a mix material 12 times and Im having to duplicate, then reconnect the structure before making my changes. Thanks!
Ctrl+c - ctrl+V.
Give all new materials new names.
Go back to node editor. Everything should be fine.
- sphericall
- Contact:
What are these about?aoktar wrote: Changes for 2.23.2 R6.1
- Scroll for side buttons with mouse wheel
- Solo mode on group buttons by RMB
Win 7 64 bit | 2 x GeForce GTX 660 | Intel Core i7-930 CPU 2,8 GHz | 8GB | Cinema 4d r15 Visualize (no Mograph, no Hair)| OCTANE benchmark scene 2,06 Ms/sec
hi,sphericall wrote:What are these about?aoktar wrote: Changes for 2.23.2 R6.1
they are related to the right buttons menu of the node editor, now you can scroll it with the wheel and with right click on groups you can "solo" them
ciao beppe
- Silverwing
- Contact:
Just tried to save an OpenEXR with different compression settings with the multi pass save settings in the octane render settings.
This does not have any impact on the size of the EXR´s.
Could it be that the connection of the selector is broken?
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
Propably yes. It's using default parameters.Silverwing wrote:Just tried to save an OpenEXR with different compression settings with the multi pass save settings in the octane render settings.
