Version 2.23.2 - R6.2 (15.07.2015) - Obsolete stable
brasco
@aggiechase37: It's to do with scale, increase Ray Epsilon.
cheers
brasc
Rig#1 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 7900K 4.7GHz | 64GB
Rig#2 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 3930K 4.4GHz | 32GB
Rig#3 Win 10 x64 | GTX 1070| GTX 1070| GTX 1070| i7 2600K 4.8GHz | 32GB
aggiechase37
brasco wrote:@aggiechase37: It's to do with scale, increase Ray Epsilon.
cheers
brasc
That was it. Thanks so much!
Chase
Win 10 - Intel 4770 - 2x Nvidia 1070 - 32 gigs RAM - C4D r16
http://www.luxemediaproductions.com
connartist
There's probably a reason this is not default, but is there any way to duplicate a connection of nodes in the node editor and maintain all the connections? Right now I'm trying to duplicate a mix material 12 times and Im having to duplicate, then reconnect the structure before making my changes. Thanks!
connartist wrote:There's probably a reason this is not default, but is there any way to duplicate a connection of nodes in the node editor and maintain all the connections? Right now I'm trying to duplicate a mix material 12 times and Im having to duplicate, then reconnect the structure before making my changes. Thanks!
It's not supported. You have to do connect by hand. Maybe for next releases.
momade
in R6.2 in PT-mode specular depth and glossy depth are called different in LV-settings and in Render Settings / overwrite kernel Settings. that shoud be the same name right?
slepy8
Go out of node editor. Select mix material with all materials connected to it.
Ctrl+c - ctrl+V.
Give all new materials new names.
Go back to node editor. Everything should be fine.
sphericall
aoktar wrote: Changes for 2.23.2 R6.1
- Scroll for side buttons with mouse wheel
- Solo mode on group buttons by RMB
What are these about?
Win 7 64 bit | 2 x GeForce GTX 660 | Intel Core i7-930 CPU 2,8 GHz | 8GB | Cinema 4d r15 Visualize (no Mograph, no Hair)| OCTANE benchmark scene 2,06 Ms/sec
hi,
they are related to the right buttons menu of the node editor, now you can scroll it with the wheel and with right click on groups you can "solo" them ;)
ciao beppe
Silverwing
Just tried to save an OpenEXR with different compression settings with the multi pass save settings in the octane render settings.
This does not have any impact on the size of the EXR´s.
Could it be that the connection of the selector is broken?
WIN 10 PRO 64 | ASUS X99-E WS | 3 X GTX 1080Ti | i7 5960X 8X 3,33GHz | 64GB RAM
Silverwing wrote:Just tried to save an OpenEXR with different compression settings with the multi pass save settings in the octane render settings.
Propably yes. It's using default parameters.
Return to “Releases”
