Octane exporter for C4D version 0.07
ribrahomedesign
Hi
me again ,and i have good news .its working now .
it was a Palm object in the scene wich has some bad textures ,i had problem with that object before ,
it seems sometimes octane does accept that palm object and other times it doesnt
anyway it works and your exporter works brilliant
thanks Abstrax
Rico
Windows 7 , 64 b / GTX 590 / Archicad 15 , 64 b / Cinema 4D R 13 studio , 64b /Intel(R)Core(TM)Extreme3,20Ghz /always latest Octane.
radiance
ribrahomedesign wrote:hi abstrax
it is not working ,and i tryed to send you the file but that is not working as well ,slow internet.
i have to try to find out whats wrong with this scene ,bit by bit ,maybe a material,the scene is
not big enough to overload the GPU
thanks
Rico
ribra, octane has a very memory hungry voxelization algoritihm, that requires it to keep a lot of temporary data during voxelisation.
32bit OS'es are limited to 1.3-1.4 max on windows.
to load my 4 million poly lamborghini model, i need to eat up to 4 GB of memory during voxelisation.
we're working on improving this, but you should really consider upgrading to an x64 operating system. it lifts the limits and you won't ever see a crash during voxelising again.
once you've worked with a x64 system with octane you won't want to go back to 32bit ever. ;)
Radiance
ribrahomedesign
hi radiance
thanks a lot for the tip, i know the benefit of 64bit and as soon i need a new machine it will be 64 bit.
Rico
abstrax
ribrahomedesign wrote:Hi
thanks Abstrax
Rico
Cool. Thanks for finding the culprit. Just to let youknow: Today I will release 0.08 which will support the export of GPU settings and daylight direction :)
Cheers,
Marcus
mantra
may i set a custome value of samples/px for animation?
becouse 32 to low & 256 to high
if it is not possible, could you to do more presets, such as 150
MY WORKS
Cinema 4d | Win7x64 | 450gts
russian octane community
http://vk.com/octanerender
katerlake
At first. Thanks for the plugin. It works on the first try very good.
When will come the sunlight?
In this week, i will wrote an german tutorial.
@ Abstrax, when will come an german version of this exporter. I can translate it. ;)
|Q8400, gtx770 4Gb |12 Gb Ram|Win7 64 Bit|C4D R15 Visualize and Octane
my 3D-Blog: http://katerlake.blogspot.com
my Vimeo: http://vimeo.com/user4046032
my FlickR: http://www.flickr.com/photos/45536398@N05/
abstrax
katerlake wrote:At first. Thanks for the plugin. It works on the first try very good.
Just done :)
Thanks for the tutorial and for the translation offer. I will translate the plugin myself, when it's finished. Maybe with the next release or so.
Cheers,
Marcus
