Scene improvements are welcome
Corona Benchmark Scene
Converted Corona Benchmark Scene.
Octane for 3ds Max v2.21.1 | i7-5930K | 32GB | 1 x GTX Titan Z + 2 x GTX 980 Ti
thanks, Rob! =)
..seen You've been making waves on their forum =DDD
1280x720 30sec per frame (100frames) 2xGTX Titan Kernel:DirectLight/ambientOcc
https://drive.google.com/file/d/0B6qdCJ ... sp=sharing
Good to see people testing, but AO looks always so fake
Can anyone improve the speed for PT?
Can someone export a .orbx for non-max users?
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
- gabrielefx
This is my version
every parameter is tweaked
regards
regards
- scene_Octane_grabielefx.zip
- (36.44 MiB) Downloaded 478 times
@ Gabriele: Thanks! But speedwise it's a lot slower/noisier now.
@ noel: Please don't do this
- gabrielefx
photorealistic vs speed balance is hard to find.
In your scene you clamped all caustics and glossy+diffuse bounces are set to minimum.
Also highlights are clamped to 1.
In interiors I set glossy and diffuse to 10 or 12, for exteriors 5-8 and caustics can be clamped because the sun generates visible fireflies hard to delete with the pixel filter.
I never create materials with diffuse shaders except when I need translucency for thin surfaces. For plants I alway mix diffuse and glossy.
For example the curtain material is wrong. There is no transparency. In reality we should add an opacity mask or mix a diffuse shader + specular with roughness set to 0,1 and index set to 1.
