LW Particles octane
Sinelab01
Hi is there a way to render hypervoxels in octane, I have a rocket and would like use octane but it will need particles for smoke or is there work around for this ?
juanjgon
Currently you can't render volumetrics with Octane. You can use a LW instancer in particle mode to instance objects, for example spheres, with some kind of specular or translucent material, but not real volumetrics yet.
Sinelab01
Ok thanks for the quick response
BraceMedia
Just for further clarification on this topic -
Is rendering volumetrics like LW does, but with Octane, actually possible?
Therefore is it a feature that 'will come' in the future, or something we will never see happen?
Thanks, and for all your development efforts,
Dom
juanjgon
At some point, Octane could support volumetric rendering, not in this 2.x dev cycle as far I know, but perhaps in the future. So yes, render volumetrics in Octane could happen in the future ;)
BraceMedia
Ok I see.
So it's not a limitation with the LW Octane plugin but rather Octane itself does not do volumetrics ... as yet.... Maybe some day it will.
mikefrisk
I found the best alternative is to run your particle simulation, then instance flat geometry with a UV. Place a transparency map and texture to that geometry. The results can be pretty good. I've simulated smoke this was with very convincing results.
juanjgon
Nice, can you please post a image or video to see the final effect?
mikefrisk
Sure!
Sorry for the super low res render, these only took 5 seconds a frame.
I originally developed this to use for semi-static clouds and tornado's. The producer ended up using some quick/cheap stock footage so I scrapped it.
I could have used more "textured squares", this one only has one. And I could have animated the texture and brought it in as a sequence, but i didn't.
If I end up working on this technique more i'll post my findings in this thread.
smoketest.mov
(1.72 MiB) Downloaded 4176 times
mikefrisk
I simplified it a bit. The shadows get weird at certain angles, but I think I know a way to fix that.
Oh, and sorry for the grain, I kept the render times short.
smoke_2.mov
(55.33 MiB) Downloaded 4170 times
Return to “Lightwave 3D”
