Hey out there
I rendered out an animation with the team renderer. I got different results in brightness from one client, working with a GTX980 ... The other clients running on quadro k5000 ... I just run a test and it has nothing to do with the team renderer. The results on two macs with different graphic cards are different....hey?
System Yosemite 10.10.2, Cinmea4dR16, CUDA 6.5....37. on all of the systems ...
Anyone out there to help.
How should I configure for team render.?
kind regards
martin
Teamrenderer problem
C. RAM Capacity (i.e. 6 GB)
do you have same version of plugin on both system?
ok. I can't remember this behaviour. is this spesific to a scene or every one? Try also manually to render the same frame on both machines, and compare it.
ok even a simple scene has a slightly difference in brightness, when the HDR texture object has no texture ...
So Maybe my light setup is the reason.... I used the one light with a daylight tag and some other normal flat lights ....
when the hdri environment object has a texture there is no difference ....strange... I will do some further tests with the lightning set up I used in the file ...
Ok it is my light setup, but I don´t know what is wrong ...
here is the simple test scene
- Simpletest2.zip
- (747.97 KiB) Downloaded 267 times
