Teamrenderer problem
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
martinzip
Hey out there
I rendered out an animation with the team renderer. I got different results in brightness from one client, working with a GTX980 ... The other clients running on quadro k5000 ... I just run a test and it has nothing to do with the team renderer. The results on two macs with different graphic cards are different....hey?
System Yosemite 10.10.2, Cinmea4dR16, CUDA 6.5....37. on all of the systems ...
Anyone out there to help.
How should I configure for team render.?
kind regards
martin
do you have same version of plugin on both system?
martinzip
yes both versions are 2.16.2 ...
I did some tests and it is really crazy, the renderings from the 980 is a lot less brighter ...
martinzip
should I try the 2.21.1 Version or update to the 2.17 standalone ??
kind regards and thanks for your support
Martin
ok. I can't remember this behaviour. is this spesific to a scene or every one? Try also manually to render the same frame on both machines, and compare it.
martinzip
Yes I rendered in the picture viewer ...
One difference there is the 980gtx is not flashed for mac ...
I will try another some simple scenes ....
I think it has to do with the daylight tag, because the background really gets darker ...
martinzip
ok even a simple scene has a slightly difference in brightness, when the HDR texture object has no texture ...
So Maybe my light setup is the reason.... I used the one light with a daylight tag and some other normal flat lights ....
when the hdri environment object has a texture there is no difference ....strange... I will do some further tests with the lightning set up I used in the file ...
martinzip
Ok it is my light setup, but I don´t know what is wrong ...
here is the simple test scene
Simpletest2.zip
(747.97 KiB) Downloaded 235 times
martinzip
I am back tomorrow ...
i think problem is different "default env color" for each plugin. Check your settings as in picture.
Return to “Bug Reports”
