Version 2.14.0 - TEST
Has anyone notified or checked new Help window? Understood the trick of usage and some internal scenes on for topics? Have you found it usefull?
rschrem
There seems to be a bug with the Cloner:
When "Render instances" is checked within the top most Cloner object I get missing geometry in the Octane Live View window after syncing (pressing the free button).
See attached example.
Is this just me or a bug? :)
pBarrelas
aoktar wrote:Hi,
Yes, it's very helpful to have it organized the way you did! Thanks
rschrem wrote:There seems to be a bug with the Cloner:
I've tested this and everything is working fine!
Win 8.1 Pro 64-bit| i7-4930k 3.4GHz | 32 Gb RAM | GTX 980 4Gb| Driver Version 344.75
rschrem
I've tested this and everything is working fine![/quote]
Hm, I added a screenshot. Did you also use Cinema R16 and the latest version of octane plugin?
pBarrelas
OK with further testing after looking at you OM, Octane can't render render instances of render instances. This happens every time you try to nest render instances inside other render instances.
Ahmed, is this a limitation or a bug?
pBarrelas wrote:OK with further testing after looking at you OM, Octane can't render render instances of render instances. This happens every time you try to nest render instances inside other render instances.
yes, it's a limit. Not easy to handle it for realtime structures. I'll look for improvements on the future. But currently we have to work like that.
pBarrelas
OK, thanks for the clarification!
kracher
i have a problem with 2.14 and cuda 344.11:
when i try to render a big project approx. 400 MB Cinemafile
my cinema crash.
but only when i use more then one gtx card
with one gtx 780 ti NO problem
with one gtx 980 NO problem
with 2 780 plus 2 980 > Cinema crash with NVIDIA error Code 9
the error appeares only wen i render in picture viewer, in live viewer there is no problem
kracher,
crash or error? Crash is getting out of of program with some windows errors.
What says octane log on Cuda error? Check you polygon counts. They can be different on render output against Live viewer. Live viewer will use subdivision for display.
virtualzapp
aoktar wrote:Hi,
Hi Ahmed,
Working on Mac, very well done!
Cheers
Regis
VFX compositor / CG generalist
Mac Pro 12C 2.93GHz, 64gb ram, 1xGTX Titan X, 4xGTX Titans in Cubix
