OctaneRender for SketchUp 2.13 - 0.13.87 updated
Forums: OctaneRender for SketchUp 2.13 - 0.13.87 updated
Re: OctaneRender for SketchUp 2.13 - 0.13.82
Postby happymilk » Fri Nov 21, 2014 7:35 pm
happymilk Fri Nov 21, 2014 7:35 pm
Same error to me :(
Win 10pro 64 | 3 x Geforce GTX980Ti | i7 5930K | 32GB
happymilk
Postby neo83_gr » Fri Nov 21, 2014 10:28 pm
neo83_gr Fri Nov 21, 2014 10:28 pm
looks great ! but when I close a window (rendering or material editor) and I open again, the window is empty. any ides? thnx
neo83_gr
Postby fuzzybro » Sat Nov 22, 2014 1:42 am
fuzzybro Sat Nov 22, 2014 1:42 am
hah, so it worked for somebody :)
okay, I'm checking what might be wrong right now.
fuzzybro
Re: OctaneRender for SketchUp 2.13 - 0.13.87 updated
Postby fuzzybro » Sat Nov 22, 2014 2:46 am
fuzzybro Sat Nov 22, 2014 2:46 am
Should be fixed, try the updated links from the main post
fuzzybro
Postby smicha » Sat Nov 22, 2014 9:16 am
smicha Sat Nov 22, 2014 9:16 am
Checking it now Bro. One, two, three and...
smicha
Postby smicha » Sat Nov 22, 2014 9:19 am
smicha Sat Nov 22, 2014 9:19 am
It works! :D
Bravo Bro. Great job.
Now the only thing I would love to see in the plugin is some king of nodal approach for materials, similar to the standalone.
smicha
Postby Seekerfinder » Sat Nov 22, 2014 1:24 pm
Seekerfinder Sat Nov 22, 2014 1:24 pm
Yes, also working for me, thanks Fuzzy.
fuzzybro wrote:[*]Removed simplified geometry on proxy load (hacky and unstable)
I still see simplified geometry? Not that it bugs me that much but just to let you know...
Best,
Seeker
Seekerfinder
Postby happymilk » Sat Nov 22, 2014 7:00 pm
happymilk Sat Nov 22, 2014 7:00 pm
Now the plugin starts
but the IPR screen remains always black
nothing can change it
happymilk
Postby fuzzybro » Sat Nov 22, 2014 9:25 pm
fuzzybro Sat Nov 22, 2014 9:25 pm
happymilk wrote:Now the plugin starts
Send me log files in the PM message please
fuzzybro
Postby resmas » Sun Nov 23, 2014 5:19 pm
resmas Sun Nov 23, 2014 5:19 pm
Hello Fuzzy.
After installing SU 2015 x64, and the new pluggin :) I have found a few blank spots in the Kernels options... :(
The Kernels don't have the new features from the Octane 2.12(and 2.13) it misses the "Coherent Mode" and "Path Term. Power" and "Static Noise"( I don't know what this one does), the "Coherent Mode", and "Path Term. Power" are awesome, please enable them for us. ;)
In the infochanel kernel it misses the "Motion Vector Pass" but I don't use it so all good for me. :lol:
The same happens in SU2014
- About simplified geometry all ok for me, I don't use it most of the times. So I don't have a problem with my component stays the way I made it.
- Proxie orbx loads perfect, even huge projects can be loaded 8-)
- A few times in SU2015 the Octane render Window just stay blank, but I cant reproduce the steps...lets wait and see if happens more times.
- a Big important thing (but is similar in older versions) is that when taking a project from one machine to another the missing textures popup is just a pain.... :evil:
For example:
- I made a new project in my laptop(working away from office), modeled, textured, render...etc etc
- then I need to take it to my workstation to continue rendering bigger files
- I copy my SU file from laptop to my workstation work folder
- I copy my SU textures to from laptop C:\Users\LAPTOP\Documents\Octane\SketchUp\temp\textures to the same directory in the workstation
- I copy all my new files to my textures library
- I copy all new .ocs/.orbx files (used as proxie) to my library
- then I open the SU file in the workstation
- the SU missing texture location opens to find the specific file, I choose C:\Users\WORKSTATION\Documents\Octane\SketchUp\temp\textures , all good. The problem is that it ask for every SU texture build for Octane. I need to select the same path to every texture. Its just hard. :cry:
Can the plugin search for all "missing" textures in that folder? (it will find them all in that directory) And then when a file is not found in there it should ask for another directory to load.
Or even a selection of locations where the plugin could always search for missing files.
This would be a huge help... ;)
thanks for the hard work mate :D
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
resmas
PreviousNext
Return to SketchUp
Users browsing this forum: No registered users and 8 guests
Tue Apr 23, 2024 2:45 pm [ UTC ]
