OctaneRender for SketchUp 2.13 - 0.13.87 updated
fuzzybro
Hi all,
This was long awaited, SketchUp x64 is finally released so here is a matching build.
Download commercial versions
OctaneRender for Sketchup 2015 x64
OctaneRender for Sketchup 2015 x86
OctaneRender for Sketchup 2014 x86
OctaneRender for Sketchup 8-2013 x86
Download matching standalone
OctaneRender Standalone 2.13
Update
Seems like there were couple of issues:
1. Fixed the installer to make sure that path to the plugin exists.
2. One of the versions required MSVC++ 2013 Redistributable but I fixed that in the update
3. Latest CUDA driver is recommended due to CUDA 6.5 update
If the build still doesn't work, please check all the points from the list.
OctaneRender for SketchUp x64
Previous build
OctaneRender for Sketchup 2.06 - 0.12.142
Changelog
  • Build against Octane 2.13 (implies all speed improvements and stability fixes)
  • SketchUp 2015 x86 and x64 support
  • Ability to load large proxies (gigabytes of data) in x64 build
  • 65000 x 65000 resolution limit for x64 build
  • Optimized texture storage to reduce memory consumption on a disk
  • Removed simplified geometry on proxy load (hacky and unstable)
  • Replaced broken SketchUp BrowseFile and SaveFile dialogs
  • Added: orbx proxies
  • Fixed material picker in Octane Material Editor
  • Fixed: picked materials were not displayed when Octane Viewport is closed
  • Fixed: no opacity when converting SU material to Octane
  • Fixed: mix material node wasn't displaying correctly in the Material Editor
  • Fixed: random error on loading scene materials
  • Fixed: minor issues in the installer
This build does not have render passes controls. To adjust render passes please export scene to .ocs/.orbx and proceed in OctaneRender Standalone.
Enjoy!
Bro
ff7darkcloud
Did I die and went to heaven? I Love this, Thanks fuzzy!!
( PC ) Win10 x64 | 2xRTX2080TI | ASUS Rampage VI Extreme | i9-7900x | 32GB | 1600W
( Laptop ) Win10 x64 | RTX2080Max-Q | Lenovo Legion Y740 | i7-9750H | 32GB - Octane Standalone Win 10/ Sketchup 2019
PORTFOLIO: https://renderspace.wixsite.com/portfolio
fuzzybro
ff7darkcloud wrote:Did I die and went to heaven? I Love this, Thanks fuzzy!!
Yes! Till you get to the first plugin crash.. :D
Seekerfinder
Thank you Fuzzyyyyyyyy!
rfox
Wow! my christmas present is coming so so early this year! Thanks FuzzyBro!
3x GTX Titan - Win7 Pro x64 - Intel i7-3930K - ASUS Rampage IV Formula-X79
smicha
I cannot start the plugin: after installation I have tons of errors. First ones are
Error Loading File C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/octane_render/init.rb
Error: 126: "cannot find the module" - C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/octane_render/ext/octanesu.so
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in `require'
ppoublan
Same issue as the one encountered by Smicha (error loading).
I thought it was due to files put in C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/... and not in C:\Users\<user>\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins... so I tried to copy files, but same error.
Any Idea ?
Yours
Pascal
ddf
I have the same issue running SU
Error: 126: Íå íàéäåí óêàçàííûé ìîäóëü.   - C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/octane_render/ext/octanesu.so
C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/octane_render/init.rb:51:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in `load'
C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/octane_render.rb:30:in `register_extension'
C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/octane_render.rb:30:in `<module:OctanePlugin>'
C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/octane_render.rb:18:in `<top (required)>'
Anton
johlanga
same here....heaven has to wait a little longer :roll:
Win7 Sp2____2xGTX1060 [email protected]____Su17.2.2555 and Su18.0.16975____SketchUp Plugin 4.00.0.17____4.00.RC7 Standalone
Seekerfinder
Hi Fuzzy,
It's trying to find the plugin here: C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/octane_render/init.rb. But that folder does not exist.
Best,
Seeker
Return to “SketchUp”
