discovered a small naming-bug.
in rendersettings its called 'glossy depth' in octane settings its called 'specular depth'. i guess its the old 'max depth' setting right?
added a screenshot.
Version 2.10.0 - TEST1 - fixed (01.10.14)
Hello, Ahmet.
In one of my projects i have strange problem, that didnt see before.
When i just open file in Cinema, Octane starts to do some job, that i dont understand. And its not a generating material preview. That job slows down whole system, and i have lags in windows gui
Log file in attach.
Log file in attach.
- octane 2.10 141002 100306.log
- (24.67 KiB) Downloaded 275 times
| i7 3930k | 32GB | gtx 1080 ti | WIN 8.1 64
keep_invironment checkbox doesnt seem to work in octane live viewer settings..
this is a output from mixmateril. Which cannot generate opengl previews. Do you have mix material on these scenes?Kemanjo wrote:Hello, Ahmet.
Log file in attach.
thanks, will check all reportsmomade wrote:keep_invironment checkbox doesnt seem to work in octane live viewer settings..
It is incredibly fast. Excellent!
Just got a strange problem. Sometimes renders extremely slowly.
The same project, the same frame:
4 seconds or 59 seconds. Video starts looking into empty space, so 4 seconds correspond to reality. This is a rendering of the Earth with high resolution textures. The video card uses about 97% of VRAM.
This problem sometimes disappears after some time passing through animation in Live Viewer, then the rendering gets going at full speed.
strange...
strange...
ASUS P6X58D-E / Nvidia GeForce GTX 780 / 24GB Ram (DDR3) / i7 950 (OC4.2Ghz-without HT) / Windows 7 x64 / and million cooling fans
VFX/CGI, Animation for documentary movies, Music videos, Products renderings, Advertising....3D/2D (small production)
Nice to hear. Try to use lower vram. It should be reason of slowdowns.Method wrote:It is incredibly fast. Excellent!
strange...
Thank you. It's possible, but can not reduce textures. This is the maximum balance that I have reached, I had a nice result.
I use GTX 780 3GB VRAM
