Version 2.10.0 - TEST1 - fixed (01.10.14)
momade
discovered a small naming-bug.
in rendersettings its called 'glossy depth' in octane settings its called 'specular depth'. i guess its the old 'max depth' setting right?
added a screenshot.
Kemanjo
Hello, Ahmet.
In one of my projects i have strange problem, that didnt see before.
When i just open file in Cinema, Octane starts to do some job, that i dont understand. And its not a generating material preview. That job slows down whole system, and i have lags in windows gui
Log file in attach.
octane 2.10 141002 100306.log
(24.67 KiB) Downloaded 271 times
| i7 3930k | 32GB | gtx 1080 ti | WIN 8.1 64
momade
keep_invironment checkbox doesnt seem to work in octane live viewer settings..
Kemanjo wrote:Hello, Ahmet.
Log file in attach.
this is a output from mixmateril. Which cannot generate opengl previews. Do you have mix material on these scenes?
momade wrote:keep_invironment checkbox doesnt seem to work in octane live viewer settings..
thanks, will check all reports
Method
It is incredibly fast. Excellent!
Just got a strange problem. Sometimes renders extremely slowly.
The same project, the same frame:
4 seconds or 59 seconds. Video starts looking into empty space, so 4 seconds correspond to reality. This is a rendering of the Earth with high resolution textures. The video card uses about 97% of VRAM.
This problem sometimes disappears after some time passing through animation in Live Viewer, then the rendering gets going at full speed.
strange...
ASUS P6X58D-E / Nvidia GeForce GTX 780 / 24GB Ram (DDR3) / i7 950 (OC4.2Ghz-without HT) / Windows 7 x64 / and million cooling fans :)
VFX/CGI, Animation for documentary movies, Music videos, Products renderings, Advertising....3D/2D (small production)
Method wrote:It is incredibly fast. Excellent!
strange...
Nice to hear. Try to use lower vram. It should be reason of slowdowns.
Method
Thank you. It's possible, but can not reduce textures. This is the maximum balance that I have reached, I had a nice result. :) I use GTX 780 3GB VRAM
cyartist
Same here
keep environment does not seem to work now.
_Fertig
Great that we finally have passes =)
Is anyone else experiencing c4d stalls when trying to stop a render in the picture viewer? It's only happening with the passes switched on.
