Dispersion test but strong colors
nuno1980
Hello. :)
My scene:
- circular tape mirrored
- ball light in inside of semi-ball mirrored
- prism w/ refractive index 1.5 and dispersion 1.0
- torus knot (blue clear) w/ index 1.6 and dispersion 0.018
screenshot:
I used PMC kernel with 32 max depth, 10k-reject, 45k-sample, caustics blur 0.00 and parallelism 2.
Strong colors are bad!? Why? Because the maxdepth 32 isn't sufficient? Will the newer version improve from 32 to 1024? Or has OR plugin for "3DS Max" infinite max depth?
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
nuno1980
Please should response! :? Due to my EASY question.
Caustics at PT
i7-12700KF
32GB DDR4@3600
gordonrobb
I'm not sure what you're trying tidy, or what you're asking :)
nuno1980
Will I need more samples? Or am I waiting new version of OR w/ max depth increased?
Caustics at PT
i7-12700KF
32GB DDR4@3600
Rikk The Gaijin
What am I looking at? :?
gordonrobb
Could you explain again which part of the image you are concerned with, perhaps circle it or something? I don't know what it is you are asking - sorry.
nuno1980
Better understand to see new image. But sorry for bad english. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
gordonrobb
OK, so you are talking about the tray caustics, on the right hand side of the image?
If you are, then you need to let it render for longer. Personally, I would reduce the maximum depth. Think of the depth as how many surfaces you want the light to go through or reflect off. With less, it may be cleaner and render faster. However, the number of samples is what will take the noise away (eventually). If you are using PMC, try Path Tracing. Also, try to add a little Caustic Blur perhaps.
All of this is assuming you want the caustics :)
btw, I have no idea what a 'circular tape mirror' is :)
nuno1980
gordonrobb wrote:OK, so you are talking about the tray caustics, on the right hand side of the image?
Tried PT but good caustics appeared are too much later.
I have changed DL imp to 0.2 and parallelism from 2 to 1 in PMC settings. I want keep 32 max depth because less max depth is less realistic.
Sounds look much better. I will post tomorrow new image with 50k- or 100k-sample. :)
Caustics at PT
i7-12700KF
32GB DDR4@3600
hi,
my suggestion is to leave the coustic blur at the default value (should be 0.010) or something near, otherwise the coustics will never clean up.
Octane 1.52 can go till 2048 max depth and all the plugin that use the this sdk can do the same.
ciao beppe
