NEW : Preview of OctaneRender 1.5
resmas
beutifull....cant wait to test it 8-)
thx for the hard work.
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
nuno1980
@RayTracey:
Please should read my previous message!
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
RayTracey
dionysiusmarquis wrote:Nice! Will it use ram caching for rendered frames?
I'm not sure what you mean by that, but you can write a script that renders each frame until a specified samplecount is reached and saves it to disk (like the turntable animation feature). You can also combine it with a camera path which is scripted or imported from an alembic file.
j7th
There are a lot of misunderstanding without description of accessible lua api commands.
Win 7 x64 | GTX560Ti | Core i7 960 3.2GHz | 24GB RAM
dionysiusmarquis
Ok, I had an After Effects like approach in mind. Play -> render frames to ram -> play again from ram (no gpu rendering happens). For quick review. At the moment you make changes the ram will be cleared.
Rikk The Gaijin
This is all very exciting, I just hope it will be easy to use, because I don't know anything about scripting, and I don't really want to be in the situation like no script=no feature...
RayTracey
Rikk The Gaijin wrote:This is all very exciting, I just hope it will be easy to use, because I don't know anything about scripting, and I don't really want to be in the situation like no script=no feature...
The LUA scripting is not hard and quite addictive. Once you get the hang of it you'll want to write a script for everything.
prehabitat
I'm looking forward to it! :D
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
nuno1980
@Raytracey:
URGENT - should response my 2 previous messages. :?
Caustics at PT
i7-12700KF
32GB DDR4@3600
Tugpsx
Regarding the inclusion of a simple editor for LUA scripting. Years ago there was a GUI drag and drop scripting add-on for LUA that was used on PlayStation Portable and other similar console. This interface was in the public domain and could easily be added to the Octane interface to add simple scripting for dropdown of pre populated simple commands. the consoles don't have keyboards so we devised a way to select simple commands from a list and submitted them to be processed. Now im not sure how much time and effort you want to spend on this process, but since it will be an integral part to adding great functionality to Octane there may be an avenue here for a spin off group or at least community input.
