HOUSE -CALERA-
snake12
Interior a House, PT 4.30 hours, 16000 maxsamples and size 2000X1100. I hope you like it. Is in process
Cosmos II, Asrock 79 extreme 11, Intel i7-3930K 4.40 GHz, 32gb Ram Quad 2.400 OC., 2 Drives Intel SSd 520 240gb Raid 0, 1 Gtx 580 3 gb + 3 Gtx 590 4Gb.
paoloverona
fiuuuuu! like a lot!
great the daylight render but...how does the broken table stays stand? (I cannot see other legs :mrgreen: ), maybe less reflectivity and more glossiness for the pillows on the left.
really really nice the nightshot too, maybe the uv mapping of the small table should be adjusted and the trees of the background looks too much added in post
Cheers, Paolo
intel i7 3820 3.6GHz, 16Gb 1600Hz, windows 7 professional 64bit, gtx 580 3Gb x2, Octane 3dsMax 2.58
snake12
In the night render the background is Hdri.
sdwhitton
like the atmosphere of the day shot..
but er the light on the background is going the other way...
probably get away with it, if this was overexposed in PS?
workstation well past its sell-by-date, Vista 64 bit (!) with a pitiful amount of RAM, re-invigorated with a GX 590
3ds Max Design 2011 (have 2013 but can't be bothered to re-do all the UI), CS5, and that free z-brush program, whatever it's called
Refracty
both are beautiful shots.
The night render could cook a bit longer.
I would suggest using a slightly longer lens for the daylight shot, stepping from 24 to 35 mm or so.
I like the imperfections of the carpet.
Well done.
S-Suini
the day image is so nice...
Intel i7 4770K - Windows 7 professionnal 64 bits - GTX 970 - 8Gb RAM
nuno1980
I'm recommeded that you try to change kernel from path tracing to PMC because PMC supports GTX 400/500.
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
snake12
Thanks refracty, the new system daylight and the post effect totally changes and improves rendering, I will try with a diferent lens, and the night render I will use PCM, but times renders I worry. Upload renders later. :lol:
snake12
Change night render, Pcm 24000 max samples 1500x1000 3.30 hr
paoloverona
Refracty wrote:both are beautiful shots.
Well done.
Hi Refracty, forgive me for the silly question but but I'm not a photographer: what result you should achieve with a 35mm lens?, an effect on the blur effect or something else?
Thanks, Paolo
