Reflective SSS Material
oguzbir
Hi Guys,
I added a glossy reflective SSS material I created earlier.
You can find at Live DB. Organic/Skin under the name Reflective SSS.
Let me know if you come up with nice renders with it.
Cheers,
My Portfolio
Elvissuperstar007
goood !!!
Slayerma
Nice render and mat.
Win 7 x64 | i7 2600K 3.7GHz | 16go DDR3 |GIGABYTE Titan | OCtane 2.06
cfrank78
It works in Standalone but not in 3ds max. Hopefully i did everything right. In Standalone Light shines through, in 3ds not. Material looks simply Amazing! Tried it with a Ring - it look 1:1 lice cnc cutted Wax. Perfect :-)
oguzbir
Thanks guys
@cfrank78
I'll look into how it performs in max.
In the mean time be sure to check your scene scale cause SSS tends to work best in real life scales.
I usually try to create my mat library in standalone.
I'm also happy to see that my render is in Octane renders Facebook
My Portfolio
oguzbir
cfrank78 wrote:It works in Standalone but not in 3ds max. Hopefully i did everything right. In Standalone Light shines through, in 3ds not. Material looks simply Amazing! Tried it with a Ring - it look 1:1 lice cnc cutted Wax. Perfect :-)
cfrank78 Hi,
Apparently, there has been mess up with the scale conversion with octane and max simply because of unit setup.
But the solution is simple. You need to lower the Scale of the Scattering Medium down to 50-100 ish..
It will always vary depending on your scene scale...
You can see a very quick messy preview render from max as a proof as well :)
I also added two hdri environment, daylight lighting renders in Max.
My Portfolio
RayTracey
Nice renders! You will enjoy this feature I think: http://render.otoy.com/forum/viewtopic.php?f=6&t=25747 ;)
oguzbir
RayTracey wrote:Nice renders! You will enjoy this feature I think: http://render.otoy.com/forum/viewtopic.php?f=6&t=25747 ;)
Thank you..
Oh my..
This is the best of all....
You will again make us refresh the forum few times a day..
Thank you for that! :D
My Portfolio
cfrank78
You were completely right - it was the scale of teh scattering.
Oh my i have to learn. So much :-P Materials in Octane are mighty - but no one click solution like i was used to :-)
3form
Just used on some candels works well in max. will post in gallery. ;)
GTX670 4GB, GTX460 2GB, Q8400 2.27Ghz, 6GB RAM
