OctaneRender® for Maya® beta 3.0 [OBSOLETE]
Moderator: JimStar
JimStar
OK, I will remove it.;)
TBFX
JimStar wrote:OK, I will remove it.
Yes, good for me too now that the esc key works. ;)
T.
Win10 x64|i7-9750H 2.6 GHz|32 GB RAM | RTX2080 max Q 8GB
jmfowler
very exciting - thanks Jimstarr!
Maya 2013 / W7 64bit / Intel i7 980 / 24GB / Gigabyte gtx 580 3GB + 2*EVGA gtx 680 4gb / MB Gigabyte X58A-UD3R / NZXT Phantom - white/black case
Maya 2013/W7 64bit/Intel i7 3820/16GB/ MB Gigabyte GA-X79-UD3 /4*EVGA gtx 680 4gb/SSD 6Gb.s /CM HAF X case
RickToxik
Wow. These improvements are really really cool. Isn't the plugin a little bit faster??? no?
1) I too have the problem with the "smooth" function on some objects. It's like it messes the normals of the object
2) I tried to push the instancing as far as I can and it eventually crashes maya. I am not sure if it involves a too large number of instances or an error produced by "instancing an instance". I include 2 crashes .dmp
Cheers, I render almost everyday with Octane for maya and always get great results.
crash instances.zip
.dmp files
(117.47 KiB) Downloaded 277 times
renmaxhb
2.58P can export and render the polygon without UVS,but 3.0 can not:
// Warning: Octane: No CUDA devices choosen to render on. Rendering on the second one: GeForce GTX 580 (compute model 2.0) //
// Error: Octane: Error getting UV IDs of object: "pTorusShape1 (UV set "map1"): //
// Error: Octane: Error mesh export. Octane render stopped. //
hope fix it :D
renmaxhb
multithreaded voxelizing is very good,so quickly :lol:
But two problemes must fix first,please,I can not wait :( ,I have a animation to render!
1 ,MESH without can not export and render,
2'Mesh cannot Edit (not only smooth)when Ipr rendering,like
renmaxhb
sorry,again
1 ,MESH without UVS can not export and render,
JimStar
renmaxhb wrote:...I can not wait :( ,I have a animation to render!
Please use the stable 2.58p release for job. This is the unstable, test release.
renmaxhb wrote:1 ,MESH without UVS can not export and render
I already fixed it, will be in next release.
renmaxhb wrote:2'Mesh cannot Edit (not only smooth)when Ipr rendering
I don't understand what you mean...
RickToxik wrote:1) I too have the problem with the "smooth" function on some objects. It's like it messes the normals of the object
Yes, I think I've found the problem... Working on the next version...
RickToxik wrote:2) I tried to push the instancing as far as I can and it eventually crashes maya. I am not sure if it involves a too large number of instances or an error produced by "instancing an instance". I include 2 crashes .dmp
Thanks, I will check it.
JimStar
Well, I have two news, bad and good.:mrgreen:
Bad: thanks to your dumps, I see that there is the little problem in Octane engine's mesh object evaluation thread-safety, which can lead to crash in rare cases (I had no these cases so far on my test scenes). So, I will be forced in the next version to disable these multithreaded calls to engine's mesh evaluation function so far...
Good: we have seen how fast it can work.;)
And given that the Octane engine team is very strong again with all the new and returned professionals, I don't think that it will take a long time to fix it or even make the native multithreaded evaluation inside the engine itself (it is a lot more effective than do it from outside by the means of plugins)...
tchoa
Great news here :)
Just a note a about the display layers: object inside a display layer won't be part of the render.
Cheers
F
Win XP x64 | Q6600 2.40GHz | 8Go | GTX470 1.28Go // Win 7 x64 | I7 Q740 1.73Ghz | 6Go | GTX460m 1.5Go
Return to “Autodesk Maya”
