OctaneRender® for Maya® beta 3.0 [OBSOLETE]
Refractive Software®/Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012 and 2013 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
Go to our online shop here: http://www.refractivesoftware.com/shop/
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 179€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
BUG FIXES SINCE LAST RELEASE:
  • Fixed bug in .ocs export (sometimes it did not export and complains about camera).
NEW FEATURES SINCE LAST RELEASE:
  • New Octane engine. Full rework of lot of plugin code, so it is the test, unstable version (in comparison to stable 2.58p). Write me about bugs - I will fix them as quick as possible.;)
  • Added Octane Falloff Texture.
  • Added Octane Color Correct Texture.
  • Added the instances support.
  • Multithreaded voxelizing realised: now the more processor cores you have, the faster you will voxelize the scene. On my 4 cores Q6600 I've got the ~1.5M polys test scene voxelized in about 5 seconds, almost 4 times faster than in previous versions... It is the unstable test version, so I think I will try to optimize it even some more in later versions...
KNOWN ISSUES IN THIS VERSION:
  • I did not optimized the LIVE-mode separate meshes refresh yet, I will do it in later versions. Thus, so far you can only refresh all meshes of the scene at once.
DOWNLOAD
Next version HERE.
Yours,
The OctaneRender™ Team.
RickToxik
Great work!!!! : ))
TBFX
Awesome! can't wait to test :D
T.
TBFX
Hi JimStar,
This may be an issue with the engine but I'm getting the following results from a simple poly sphere. No instancing involved.
This happens in all of the render kernels.
First the sphere with a non smoothed octane shader - result as expected.
Now check the smooth attribute of the octane shader on - weird shading
With the octane shader smooth off and one level of geometry smoothing - result as expected
Now turn the shader smooth on again - really weird result :(
T.
hyubrad
hi
does BETA 3.0 support GTX 6XX?
Win 7 x64 | MAYA 2016 | OctaneRender 2.3 | GTX 980TI * 3 | CORE I5 2500 | 16 GB RAM .
renmaxhb
Woh,my god!
TBFX
Geometry is not inheriting transforms from it's parents. Only transforms directly on the objects transform node seems to have any affect. I have tested this on both instanced and non instanced geometry with the same result.
T.
Krisonrik
I haven't tested much of Octane for Maya since it's public beta release. This is the first time, but it crashed on me the moment I clicked on the create spec material button from the shelf under Octane tab. Also, somehow, everything seems to take forever to respond now.
Please give a bit more information on how does the instance work in Octane for Maya.
I also encounter that after assigning octane material to mesh and then open hypershade cause hard crash.
Dual Lindenhurst single core Xeon 3.6Ghz with Hyperthreads, 8GB DDR-2 ECC, Geforce GTX 260
Dual Xeon 5680 3.2Ghz with Hyperthreads, 24GB DDR-3 ECC, Quadro 4800 & GTX 480
Hatak
Thanks Jim!
Tell me pleas, new frenel model of glossy including in this releas? Thanks!
My english is bad. Sorry D:
Dual Core E6700 3.2Ghz | GTX 580 | 4gb ram | Win7 64 |
Karba
Hatak wrote:Thanks Jim!
Not yet, it is an experiment. I need to see, how it will affect current 3dsmax scenes of users.
Return to “Autodesk Maya”
