OctaneRender® 2026.4
mojave
Hi all,
We are excited to bring you OctaneRender 2026.4. Thanks again to all those who sent us feedback and continuously help us improve Octane.
This version includes a number of fixes as well as improved support for Gaussian splats and Neural Radiance Cache.
Important notes:
  • The minimum NVIDIA driver version required is R555 (R572 for GeForce RTX50 series).
  • The minimum version of macOS required is 14.5.
Changes since 2026.3
New features
  • Added support for MacBook Neo
  • Added support for SPZv4 Gaussian splats
  • Added support for Neural Radiance Cache (NRC) on macOS (requires macOS 15+)
  • Added support for network rendering with NRC
  • Added support for importing UV vertex attribute names from FBX material data if no Octane material data is present; set UV set index if it is one of the Octane-specific UV names used for those
  • Added octane.json.tryDecode to the Lua API.
Improvements
  • Added prompt to select images if the source files are not found for tiles and UV tiles
  • Reduced GPU memory usage for Gaussian splats
  • Improved reproduction of complicated node graphs when importing FBX with embedded Octane OCS material data
  • Added ability to import from and export to FBX planar UV mapping type
Resolved issues
  • Fixed CUDA error when rendering huge Gaussian splats (30+ million primitives)
  • Fixed invalid attribute ID log message when selecting a new file for a texture file name input on an OSL node
  • Fixed network rendering with Vectron nodes
  • Fixed occasional crash when loading a scene with a lot of meshlets or virtual textures
  • Fixed an issue where USD geometry was not correctly connected with its material
  • Fixed bug in loading PLY files with spherical harmonics degree 4. Octane currently supports spherical harmonics up to degree 3
  • Fixed bug that extra spherical harmonics loaded from .PLY files could be incorrect
  • Fixed crash when rendering PMC kernel with small resolution (e.g. 1x1, 1x2)
  • Fixed incorrect loading progress values when loading large scenes
  • Fixed potential application crash during startup
  • Fixed render failure in scenes with post-FX light beams after resetting devices due to a device selection change or in multi-GPU setups
  • Fixed issue where Octane stole focus while running a Lua script every time it loaded a new scene
  • Fixed artifacts in caustics cast by objects with normal maps based on height maps
  • Fixed issue preventing splash screen from showing sometimes on macOS
  • Fixed issue causing files to get locked when nodes were copied to the clipboard
  • Fixed issue preventing ORBX files from being opened on macOS when double-clicking on them
  • Fixed issue where vertex displacement updates were not triggering render updates when connected to a vertex displacement node
  • Removed unnecessary logging displayed occasionally with some NVIDIA driver versions
Other changes
  • Changed Mesh UV using UV set 1 to be translated to the UV name "default" in FBX files, matching the default value documented by the format
Downloads
Studio+ Downloads
OctaneRender Studio+ 2026.4 Standalone for Windows (installer)
OctaneRender Studio+ 2026.4 Standalone for Windows (ZIP archive)
OctaneRender Studio+ 2026.4 Standalone for Linux
OctaneRender 2026.4 Standalone for macOS
OctaneRender Studio+ 2026.4 Node for Windows (installer)
OctaneRender Studio+ 2026.4 Node for Windows (ZIP archive)
OctaneRender Studio+ 2026.4 Node for Linux
Demo Downloads
OctaneRender Studio+ 2026.4 Standalone Demo for Windows (installer)
OctaneRender Studio+ 2026.4 Standalone Demo for Windows (ZIP archive)
OctaneRender Studio+ 2026.4 Standalone Demo for Linux
Studio+ Chinese Downloads
OctaneRender Studio+ 2026.4 (Chinese) Standalone for Windows (installer)
OctaneRender Studio+ 2026.4 (Chinese) Standalone for Windows (ZIP archive)
OctaneRender Studio+ 2026.4 (Chinese) Standalone for Linux
OctaneRender Studio+ 2026.4 (Chinese) Node for Windows (installer)
OctaneRender Studio+ 2026.4 (Chinese) Node for Windows (ZIP archive)
OctaneRender Studio+ 2026.4 (Chinese) Node for Linux
Happy rendering,
Your OTOY Team
Kalua
Thanks, team!
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
Aszyk
Hello,
I'm trying to import USD points into Octane Standalone from Houdini.
With static point counts, this works fine, however with varying point counts, it doesn't seem to open at all.
Wondering if this is a bug or a feature that's not been implemented yet.
Win 11 64 | RTX 4090 x 2 | AMD Threadripper 3970X 32-Core Processor 3.70 GHz | 112 GB RAM
https://www.nealcoghlan.com
vijay
Aszyk wrote: Tue Jul 21, 2026 6:05 pm Hello,
This issue has already been fixed. The fix will be included in the next release.
Vijay
Aszyk
vijay wrote: Tue Jul 21, 2026 9:56 pm
Vijay
Ah amazing! so glad to hear that.
Lewis
Hi DEVs,
Please fix "affect specular" option on Lights with Shadow Catcher/matte material.
Currently all 2024/2025 and 2026.x releases have this BUG. Last one when it worked is 2023.1.3.
Here is the simple scene attached
And Video to demonstrate BUG.
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
mojave
Lewis wrote: Mon Aug 24, 2026 5:23 pm Hi DEVs,
Thank you for such great report, we will look into this and fix ASAP.
manalokos
There is a behaviour on this new version that is very inconvenient, not sure if it is a bug or a feature.
Usually when I copy/cut and paste something that is on the scene, I can paste it anywhere and it pastes immediately because all the assets are in memory.
But on this 2026.4 version, whenever I paste something that is already in the scene octane reloads all the assets like it is loading it again from disk.
Anyone else noticed this?
Kind regards
Filipe
mojave
manalokos wrote: Tue Aug 25, 2026 10:01 am There is a behaviour on this new version that is very inconvenient, not sure if it is a bug or a feature.
Kind regards
Filipe
Thanks for the report, may I ask you to share a simple scene where this behaviour can be reproduced with a list of step to do so?
manalokos
Hi, there is no specific scene where this happens, I can give you the steps to replicate:
1 - Empty scene
2 - import a heavy obj or image, like 1gb or something
3 - Copy the node with ctrl-c
4 - paste anywhere in the nodegraph
When pasting it will reload the data like you never loaded it before...
Let me know if you can replicate it.
Kind regards
Filipe
mojave wrote: Tue Aug 25, 2026 6:29 pm
Kind regards
Filipe
