OctaneRender® 2026.3
mojave
Hi all,
We are excited to bring you OctaneRender 2026.3. Thanks again to all those who sent us feedback and continuously help us improve Octane.
This version includes a number of improvements and fixes especially targeting, but not limited to the latest features.
Important notes:
  • The minimum NVIDIA driver version required is R555 (R572 for GeForce RTX50 series).
  • The minimum version of macOS required is 14.5.
Changes since 2026.2
Improvements
  • Added support for network rendering when using virtual textures.
  • Added support for color4 output to Baking texture, UV Tiles and Tile grid image nodes.
  • Added opacity texture pin to Baking texture node for use when baking to a color4.
  • Added Vectron tube primitive.
  • Added MaterialX import support for displacement shader sub graphs.
  • Reduced memory usage when using NRC.
  • Added support for importing float and color primvars from USD curves.
  • Reduced time to first sample in render nodes with scenes with large image counts.
  • Added tooltips to Volumetric spotlight nodes inputs.
  • Trace set visibility rules can now also be applied on shadow catchers.
  • Added ability to override point instances in USD import preferences so they can be used to instance other external geometries.
  • Added option to clamp high quality displacement values at the uv edges.
Resolved issues
  • Fixed some scenarios where the high quality displacement would cause artifacts.
  • Fixed MaterialX TransformNormal and TransformPoint to operate on normals and points properly.
  • Fixed errors logged when loading scenes with MaterialX Time and Frame nodes.
  • Fixed import of LiveDB glossy materials with IOR/Film-IOR.
  • Fixed application crash when loading a DDS file and opening preferences.
  • Fixed issue causing the last frame of 2-frame animation to produce an invalid value.
  • Fixed loading of scenes containing the MaterialX Ambient Occlusion node across Octane versions.
  • Fixed usage of select() OSL function in shaders with values that require differentials, eg. UVs for virtual textures.
  • Fixed a rendering regression in low quality texture displacement on Windows and Linux platforms introduced in version 2025.1
  • Fixed MaterialX HexTiledImage node Alpha blending for color4 outputs.
  • Fixed RGB Image node with Color4 output in normal input failing to compile.
  • Fixed issue causing other geometry to disappear when changing high quality texture displacement settings.
  • Fixed incorrect loading of some point instancers from USD archives.
  • Fixed incorrect loading of USD points from USD archives.
  • Fixed meshlet mesh geometry missing in the scene statistics in some circumstances, i.e. when it is a memory-only meshlet mesh that is being built during the scene compilation.
  • Mitigated issue that would cause some RNDR uploads to fail.
  • Fixed load error when loading an animated Alembic file with materials saved as non-constant FaceSet objects.
  • Fixed issue causing excessive memory usage with low quality texture displacement.
  • Fixed OpenPBR Dispersion Abbe number input range to allow it to go all the way to 0.
  • Fixed OpenPBR dispersion scaling when using Cauchy dispersion mode and when switching modes.
  • Fixed MaterialX import issues around bi-tangent inputs that could break normal mapping.
  • Fixed incorrect handling of empty file name input/nodes where Octane replaced them with the directory of the OCS file containing the node. They now always stays empty.
  • Fixed an issue where motion blur was not visible when using USD curves.
  • Fixed potential application crash when loading some USD scenes.
  • Fixed an issue causing some USD assets not to be included when re-saving the ORBX package.
  • Fixed layout of UV tiles when enabling virtual texturing.
  • Fixed render errors when virtual texture builds are queued and cancelled repeatedly in quick succession.
  • Fixed baking texture nodes sometimes not updating in situations where they are repeatedly copied.
  • Fixed an issue with the FBX exporter causing vertex animations not to be exported.
  • Fixed an issue with the FBX importer causing incorrect loading of vertex attributes.
  • Fixed render artifacts displayed when using volume/media in combination with NRC.
  • Fixed an application crash when rendering is started while virtual textures are being compiled and they are used in texture displacement (please note that virtual textures are not supported for texture displacement).
  • Fixed an issue causing FBX vertex animations to result in empty frames at the end.
  • Fixed an application crash during the render stop happening when multiple devices were denoising.
  • Fixed application crash when loading unsupported or invalid SPZ files.
  • Fixed potential application crash upon initialization on Windows and Linux.
Other changes
  • Changed rotation of anisotropy in Standard Surface to match with OpenPBR and other renderers (existing scenes are not affected).
  • The tile set node was renamed to tile grid image. (This type represents a single large image divided up into multiple files in a tile grid, which is often done for gigapixel images.)
  • When running a script the stop button does not have keyboard focus by default.
  • MaterialX importer now imports UsdPreviewSurface as Standard Surface instead of Universal material to align with the USD importer.
  • Changed the default values of some OpenPBR inputs to align them with the specification.
  • The HDR viewport on macOS will no longer use the OCIO view set in the imager node (if there is one). To preview sRGB output, disable HDR viewport in color management settings.
Lua API
  • octane.node.setAnimator(), octane.node.setArrayAnimator(), octane.node.setAttribute() and related functions accept raw C arrays for situations where the API expects an array. setRawArrayAttribute is still available as an alternative for setattribute() but this one only accepts raw C arrays.
  • Added getAnimatorType() and getAnimatorTypeIx() to octane.node and octane.nodegraph to query the data type of the animator of an attribute.
  • For non-array attributes you're allowed to set animators with different channel count from that of the attribute type.
  • Added getRawAnimator() and getRawAnimatorIx() to octane.node and octane.nodegraph to retrieve animator data as a raw C array.
Downloads
Studio+ Downloads
OctaneRender Studio+ 2026.3 Standalone for Windows (installer)
OctaneRender Studio+ 2026.3 Standalone for Windows (ZIP archive)
OctaneRender Studio+ 2026.3 Standalone for Linux
OctaneRender 2026.3 Standalone for macOS
OctaneRender Studio+ 2026.3 Node for Windows (installer)
OctaneRender Studio+ 2026.3 Node for Windows (ZIP archive)
OctaneRender Studio+ 2026.3 Node for Linux
Demo Downloads
OctaneRender Studio+ 2026.3 Standalone Demo for Windows (installer)
OctaneRender Studio+ 2026.3 Standalone Demo for Windows (ZIP archive)
OctaneRender Studio+ 2026.3 Standalone Demo for Linux
Studio+ Chinese Downloads
OctaneRender Studio+ 2026.3 (Chinese) Standalone for Windows (installer)
OctaneRender Studio+ 2026.3 (Chinese) Standalone for Windows (ZIP archive)
OctaneRender Studio+ 2026.3 (Chinese) Standalone for Linux
OctaneRender Studio+ 2026.3 (Chinese) Node for Windows (installer)
OctaneRender Studio+ 2026.3 (Chinese) Node for Windows (ZIP archive)
OctaneRender Studio+ 2026.3 (Chinese) Node for Linux
Happy rendering,
Your OTOY Team
Pelana001_1
Thank you for new update, I'll test soon
Windows 11 Pro for Workstations x64, Ryzen 5950x, 128 Gb ddr4 Bus 3600 mghz, Noctua NH-D15, M2 1 Tb SSD WD Black SN850X NVMe 7300 mbps, 8 SSD HP S650 1 TB, 1 RTX A4000, power source Corsair 850 w Platinum Series, mb X570 wifi plus Asus
martinzip
Dear Mojave
it would be great to have the Macos render nodes back!?
With the upcoming M5 Ultra and the power of the next M6 it will be worth to have some mac nodes running.
There are a lot of user out there seeking for the macos render nodes also because of the huge VRAM of the mac.
Kind regards from sunny cologne
Martin
PolderAnimation
Question: when working with “heavy scenes” (not even that heavy actually), but I do have some displacement, turning lights becomes extremely slow, and it looks like it evaluates the whole scene again.
When I delete all the displacement, it’s way more responsive for lighting. Is there an option to disable all displacement maps in the kernel for faster feedback or something like that? I can send a file if that would be handy? but that will be a private message because its for a big client (NDA).
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
mojave
PolderAnimation wrote: Fri May 15, 2026 2:48 pm Question: when working with “heavy scenes” (not even that heavy actually), but I do have some displacement, turning lights becomes extremely slow, and it looks like it evaluates the whole scene again.
While there is no global setting that allows turning displacement on and off, you can setup your scene to use a material switch node between the actual material applying displacement and the geometry node. Each of these material switch nodes would connect their first input to the specific materials to use in each case and all of the material switch nodes in your scene will use the same default material with no displacement as their second input. All material switch nodes can then also connect to a single shared int node to control the input material that is applied to the output, this way you can control all materials just by updating this.
PolderAnimation
mojave wrote: Sun May 17, 2026 10:18 pm
Thanks for the reply, unfortunately that is not a solution for our pipeline and the way we work. We have hundreds of assets in separated ABC files in separated groups (so its nicely structured and clean). We have a pipeline that we can publish assets as an contained .ocs file with the shaders, textures for that ABC model.
We will will make a toggle of our own then because responsive lighting is super imported (and one of the main reasons we use octane).
PolderAnimation
When using a VDB volume sequence in which some VDB files contain 0 voxels (resulting in a file size of around 1 KB), Octane does not handle the empty frames correctly.
Rendering works as expected for frames where the VDB contains voxel data. However, when Octane encounters a VDB file with 0 voxels, it randomly loads a different VDB volume from the sequence instead.
(I can make an example file next week if needed).
john_otoy
PolderAnimation wrote: Thu May 21, 2026 9:30 am When using a VDB volume sequence in which some VDB files contain 0 voxels (resulting in a file size of around 1 KB), Octane does not handle the empty frames correctly.
Can you put together an example and PM me with a link to the orbx?
northalex78
I can't get network rendering working for Mac to PC, using this version 2026.3 in Mac/Standalone, PC Standalone and Node, and C4D plugin.
Can't tell if this is a bug or something is wrong on my end.
Daemon seems to bind OK. All daemon settings default, port 48000. PC is receiving pings from Mac on that port. No nodes ever show up in network render settings on Mac.
northalex78 wrote: Sat Jun 27, 2026 6:45 am I can't get network rendering working for Mac to PC, using this version 2026.3 in Mac/Standalone, PC Standalone and Node, and C4D plugin.
Here network rendering is working as expected in 2026.3, with macOS as primary machine, and PCs as Render-Nodes.
Please write to help at otoy dot com so I can check your setup.
ciao,
Beppe
