OctaneRender for Blender Addon 2026.3 - 31.9 (for Blender 5.1.2) [OBSOLETE]
azen
We are excited to bring you the first Stable Release, for the OctaneRender for Blender Addon! With this release, there will no longer be any need for a custom-built Blender version anymore!
This Addon Release is only compatible with Blender 5.1 - previous Blender 5.0 and 4.x releases are not supported.
This version works on the "vanilla" Blender 5.1.2 release, that you can download and install from the Blender Foundation website ( https://www.blender.org/ ).
1. OctaneRender™ Server
2. OctaneRender for Blender Addon
How to Install
  • Download the addon and the server files
  • Unzip the Octane Addon Server in any location on your hard drive
  • Launch the Octane Addon Server
  • Launch Blender and from Preferences/Addon, install the Octane for Blender addon
  • Select File > New > OctaneRender Startup (Direct Lighting) or File > New > OctaneRender Startup (Path Tracing)
  • Quit Blender
  • Launch Blender again
CHANGES SINCE LAST RELEASE
  • Supported point cloud display color as Octane color attribute
  • Supported "Always use camera resolution" for OSL cameras
  • Added "Use Object Layer for Instances" (default off). When on, the collection's Object Layer applies to all of its instanced children; when off, each child keeps its own Object Layer
FIXES SINCE LAST RELEASE
  • Fixed loss of Object Layer on collection instances
  • Fixed the Local DB list not refreshing without a server restart
  • Fixed imported Transform value nodes becoming Camera Transform
  • Minor Bug fixes
You can read about new features of OctaneRender™ 2026.3 here:
viewtopic.php?t=85624
Octane Blender Addon
All Platforms
Blender Addon - All Platforms - Studio/Prime Edition
OctaneServer
Studio+ Edition - for Studio+ Subscription Users
Octane Server - Windows
OctaneServer - Linux
Prime Edition - for Prime (Free-Tier) Edition Users
Octane Server - MacOS (Metal)
Usage
  • Start with a default scene (File > New > OctaneRender Startup (Direct Lighting) or File > New > OctaneRender Startup (Path Tracing))
  • Convert a scene from the non-addon version: "File > Export > OctaneBlender Addon". Please report any problem you may find when converting your scenes!
Bug Reports
For faster troubleshooting, please provide as much information as possible. Please include:
  • Steps that you took to trigger this bug, so that we can reproduce it (ideally, please also provide screenshots)
  • If possible, Blend files for direct testing would also be appreciated
If you are unable to share a copy of the affected scene, please try running Blender in debug mode and send us the logs instead.
  • Open the directory of the Blender executable file.
  • Double-click the blender_debug_log.cmd file to open it.
  • This will launch Blender in debug mode and automatically start capturing logs.
  • Reproduce the issue you are experiencing in Blender.
  • Once you have finished reproducing the issue, close Blender.
  • Blender will open a folder containing error log files.
  • You can then send us the blender_debug_log.txt file to help us diagnose the issue.
You can get more information about the debug command at https://docs.blender.org/manual/en/latest/troubleshooting/crash.html.
