Motion blur issue
remKa
Hello,
there is a bug with the motion blur, everything works fine when I put the motion blur in the general camera setting but is doesn't work inside the camera modifier, please see attached file.
MB.mp4
(4.66 MiB) Downloaded 79 times
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
paride4331
Hi remKa,
It looks like something might be getting stuck. Could you double-check on-off the Motion Blur settings for the affected objects in the Octane Object Properties panel and then try adjusting the camera’s Motion Blur slider again?
Regards
Paride
remKa
Hello, that's not working, it happens on every scene
paride4331
remKa wrote: Mon Mar 02, 2026 4:02 pm Hello, that's not working, it happens on every scene
Hi remKa,
Yes, I meant that there’s something that needs to be fixed, but in the meantime it’s a workaround.
Regards
Paride
paride4331
Hi remKa,
The issue should be fixed in the next release.
Regards
Paride
remKa
Hi, thank you !
remKa
Hello Paride,
I also have depth of field issues sometimes with universal camera, I have to relaunch the octane viewport to get it right (every objects are movable proxies) :
Enregistrement de l'écran 2026-03-10 143344.mp4
(10.09 MiB) Downloaded 52 times
It happens when I switch between cameras :
Enregistrement de l'écran 2026-03-10 144006.mp4
(5.76 MiB) Downloaded 63 times
paride4331
Hi remKa,
I can’t reproduce the issue. It seems like it might be related to the scene scale, but if that were the case it should always occur with the Real Camera. Does it happen only in that scene, or in other scenes too?
Regards
Paride
remKa
Hello Paride,
this is with the Universal Camera, not the real camera, it does happen on other scenes yes
Return to “Autodesk 3Ds Max”
