Hello,
there is a bug with the motion blur, everything works fine when I put the motion blur in the general camera setting but is doesn't work inside the camera modifier, please see attached file.
Motion blur issue
- MB.mp4
- (4.66 MiB) Downloaded 13 times
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
- paride4331
Hi remKa,
It looks like something might be getting stuck. Could you double-check on-off the Motion Blur settings for the affected objects in the Octane Object Properties panel and then try adjusting the camera’s Motion Blur slider again?
Hello, that's not working, it happens on every scene
- paride4331
Hi remKa,
Yes, I meant that there’s something that needs to be fixed, but in the meantime it’s a workaround.
- paride4331
Hi remKa,
The issue should be fixed in the next release.
Hi, thank you !
