Conversion of old materials?
dinf
Hi there,
is there a fast and easy way to convert v2020 Materials into v2026? It is from a pack we bought and now most of them are useless. Some seem to be wrongly wired (depends on Octane version), some are simply crashing Cinema/Octane - and this fast and often :( I sometimes open a scene, click on a material - and C4D is going "asleep" forever. Some have to be rewired, or it is like metalness had to be activated and different other things. Some easy, some complicated. We already converted Mix materials into the Composites wich worked well so far and was fast and easy. Has been only a few.
I am working in R20 for the conversion to get the v2020 to run so I don't have to switch it in R21 back an forth.
And is there a way to convert Layered Materials automatically? I tried the manual way with exchanging the layer and using a submaterial instead. Wich looks different sometimes, and this way may take really long.
So if there's a way ...
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
Try to export from R20 to Standalone, then open the .orbx scene with Standalone 2026.2, and check that all materials are converted correctly, then save the orbx scene.
You can right-click on a material and choose Render.
Then, back in C4D, you can go to Live View menu File and use the "Unpack Package (ORBX)" command, to import all materials at once:
ciao,
Beppe
dinf
Hey Beppe,
thanks for your help.
Maybe you can help a bit furtheron?!
Everything works fine up to loading and rendering/checking the materials in 2026.2 standalone, and also saving everything as ORBX-scene.
It is possible to reload them into standalone. The biggest material-scene (360 MB) takes about 10 sec with 50 textures, wich are the 360 MB.
But it all stops at C4D importing/unpacking the ORBX files. Either C4D crashes or I stop it after about 20 to 40 minutes. It is a pitty that there is also no progress bar for the process (in case i am not blind ..).
Importing will take similar time, but it seem to be impossible to convert the import into C4D-objects or - here - materials.
Is there maybe another way?
Thanks alot!
Edit, btw.: OctaneC4D can load, but standalone can't save MaterialX, right? And standalone can save, but plugin can't load OCS files, right?
Hi Dinf,
Could you share the 360mb .orbx 2026.2 file with me via PM?
ciao,
Beppe
