OctaneRender for DAZ Studio 2025.2.1 - 403 [OBSOLETE]
Moderator: BK
BK
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for DAZ Studio - TEST (ie. pre-release) and STABLE releases.
SOLUTIONS TO COMMON ISSUES
1) Make sure your NVIDIA drivers are up to date.
2) Make sure you are running the latest version of the OctaneRender for DAZStudio plugin.
3) If you experience a DAZStudio crash - deleting C:\Users\[username]\OctaneRender\Data\OctaneRender_settings.oczdb may resolve the issue.
This also resolves the "COULD NOT INITIALISE IN-MEMORY DB!" error on startup and a number of other issues.
4) If the Save button is disabled when using the Final button - disable the Final button and in Render settings select the SuperScope (2:1) Size / aspect ratio and drag the Viewport height or width until you reach required resolution.
5) If rendering an animation fails after 11 frames - make sure the DAZStudio viewport is visible when you render the animation.
6) If Octane materials are not loading when you load a previously saved scene - tick Preferences->Load OctaneRender materials from .duf user presets. If ticking this option does not stick between DAZStudio restarts, delete OctaneRender_settings.oczdb as per NOTE 3 above.
7) If you get a "Could not save a frame for X times!" - please search the forum for potential solutions.
8) If you get a "Bogus Scene Path" error - this is due to having an apostrophe in the filepath of a texturemap (so store your textures in foldernames which do not have apostrophes).
9) Octane panel title bar is off the screen and cannot be closed - click anywhere on the Octane panel and then press Alt-F4.
10) Rendering animation results in the scene emitter intensities changing - this is because rendering animations is done in "Final" mode, where meshes are merged. To resolve this, UNTICK the Preferences->Use Combined Mesh, or ENABLE the Surface Brightness pin on each of the emission materials in the scene.
11) Denoiser is not working - make sure you have a graphics card selected for Denoising in the System tab->Open Device Settings window, and that you are using the Path Tracing kernel.
12) Render artifacts near eyebrows - this is due to the eyebrow geometry going inside the head mesh surface. So morph, move or scale the eyebrows so they do not intersect with the head mesh.
13) Octane panes do not appear on the screen (ie. they open off the screen) - Main Menu Bar->Window->Workspace->Select Layout->Accept (you might choose a different layout to the current layout to make this work).
KNOWN ISSUES AWAITING RESOLUTION
1) Panoramic camera and OSL nodes are not currently supported.
2) Templating is not currently working for specular and roughness maps from Iray materials. - FIXED (please report any issues)
3) UDIM Tiles are not currently supported. - FIXED (please report any issues)
4) Some of the newer OctaneRender material and texture types are not supported. - FIXED (please report any issues)
5) VDB volume and volumetric spotlight nodes are not currently supported.
DAZ Studio Version
DAZ Studio 4.8 or later on Windows 8, 10 or 11 64bit
To use this version, you need a GPU of compute model 3.5 or higher.
Also, make sure you use an Nvidia Studio driver of version 456.38 or higher.
The minimum NVIDIA driver version required is R528 (R572 for GeForce RTX50 Series).
Network Rendering
For Network Rendering, you must use the OctaneRender Studio+ Node release from the Octane Standalone forums/download page which matches the exact Octane version of the plugin you are using. This version matches OctaneRender Studio+ 2025.2.1 Render Node builds.
Support Issues
If you have a support issue, pls provide the following information:
- Operating System (ie. Win 8, 10, 11)
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
- DAZ Studio version
- The most important part of resolving a problem is being able to reproduce that problem. So pls provide as much detail as possible in order for me to do this, and if the problem is specific to the scene, send me the scene.
What's new in OctaneRender for DAZ Studio 2025.2.1 - 403
  • Converted build system to CMake
  • Updated the renderer to 2025.2.1
We are updating to the latest OctaneSDK and is in the works, however, we don't have an ETA yet
FAQ
Q: How to change light brightness/color?
A: You need to assign a material to the light and adjust the emission of the material. You can do it either by dragging a material to the light in the Materials tab (similar to assigning materials to geometry) or by right clicking on the light and selecting menu item under "Create as new light source".
Q: How do I enable analytic light?
A: Create a point light (or linear point light, they are the same). Then turn on "use analytic light" in the OctaneRender settings.
Q: I selected "rectangle" light geometry, but light didn't change
A: "rectangle", "disc" and "cylinder" geometries are only supported for analytic lights
Q: I assigned emission material to the light, but it's still not visible
A: If the light is analytic, make sure the emission node is expanded (i.e. is a separate node, connected to emission pin). It's required for analytic lights to work.
Q: How to make light beams work?
A: 1) Set the light to be analytic, rectangle or disc shape, enable "use in post volume".
2) In render settings enable post processing and light beams
Download Links
Please feel free to report any issues you encounter.
Happy rendering
Your OTOY team
Kind Regards
bk3d
RGUS
Awesome!!! Thank you.
After running the Prime install file and then loading DAZ Studio 2025.
How do I get the Octane Tab and menu to show?
I do have DAZ Studio 2024 installed, of course, is this upsetting the install?
WEB: http://rgus.deviantart.com/
GPU: NVIDIA GeForce RTX 3090 Ti
RAM: 64GB
CPU: 12th Gen Intel(R) Core(TM) i9-12900K 3.20 GHz
OPERATING SYSTEM: Windows 11 Pro
OCTANE PLUGIN VERSION: 2025.6.0.4.09 Prime BETA
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
BK
Hi Rgus,
Thanks for the post..
Yeah, it may be corrupt *OctaneRender_settings.oczdb* please try deleting it.
Which Daz version are you running btw? We tested with Daz 4.23
cheers
Kind Regards
bk3d
RGUS
OK....
I deleted the file... re-installed and...
So, is this release supposed to work with DAZ Studio 2025 (6.25) Public Build?
It loads and works quite happily so far with DAZ Studio version 4.24.0.3 (64-bit)
Is this the intended version for the plug-in and not DAZ Studio 2025?
Thanks for your work.
RAM: 64GB
huakiami
Hi RGUS - I don't believe this was built for Daz Studio 2025, based on the comments from the OTOY team in the previous thread. They noted they would look into Daz 2025 after getting the plugin up to date with more recent Octane versions.
BK and OTOY team - I do think it would be prudent for a minor nomenclature change regarding the plugin, as the current title "OctaneRender for DAZ Studio 2025.2.1- 403" sort of suggests it's for Daz Studio version 2025, not that it's OctaneRender 2025. Maybe calling it "OctaneRender 2025.2.1 - 403 for DAZ Studio" would be better given Daz named their latest release "Daz Studio 2025".
Confirming it is working for me in Daz Studio 4.24.
RGUS
Yes working in 4.24
RAM: 64GB
jay3dlinux
RGUS wrote: Wed Jun 25, 2025 4:15 am So, is this release supposed to work with DAZ Studio 2025 (6.25) Public Build?
We cannot currently release support for DAZ Studio 2025 due to the unavailability of a public SDK from DAZ. We anticipate DAZ may release their SDK following the completion of their alpha or beta testing phases, though the timeline for this remains uncertain.
Once the SDK becomes available, additional development time will be required to adapt our plugin due to the significant architectural changes, particularly the transition from Qt4 to Qt6.
Meanwhile, we continue focusing on implementing missing Octane features in our current plugin to address longstanding gaps in functionality.
This should clarify our current development priorities and constraints.
SiliconAya
First off, thanks for the update!
I just got this crash while using this new version of the plugin and while access violation crashes are rather common in Daz Studio, this is the first I've had that lists octane.dll in a long time (years?), as there was a concerted effort to report and fix them all a while back.
At the time I was panning the camera, which doesn't really seem related to the crash, so not sure that helps.
Is there anything else that should be provided next time i get a crash or is this enough?
Hun73rdk_1
Delete Render settings does not work under rendersettings manegement the button is grayed out what ever i try one or all selected
Join the Octane Daz Fan server for people that uses daz and octane https://discord.gg/wDzwC8tqAK
filipe_sheepwolf
Awesome news! I'll comment if I find any new bugs.
May I ask if VDB/Volumetrics support is coming? It's lack of support is another thing that keeps forcing me to use Iray
Return to “DAZ Studio”
