Nvidia no signal 2000-5000 RTX 10000% SOLVED
Elvissuperstar007
https://www.youtube.com/watch?v=gT7qHMLUKj4
What not to do:
Reinstall Windows, update motherboard Bios, update CPU drivers, return the video card under warranty - it's 1000% working! it's all about the drivers.Don't use left power cables for the video card
What you need to do:
Find out the exact revision of your video card, my 4090 TUF has as many as 4 different revisions and find the latest BIOS for the one you need, then if you have monitors with HDMI support just switch to them it will solve all problems, if you want to use DP then buy a plug for HDMI port for example (HDMI to VGA) and do not pull it out ever! Any crooked drivers will cease to be scary.
THANK YOU!
Here see what revisions of video cards , each name affects the bios, they are all different
https://www.techpowerup.com/gpu-specs/g ... 4090.c3889
Elvissuperstar007
I spent six months solving this problem and tested the video card on several computers with different configurations. Older drivers also did not fix the issue, something happened at the end of August 2024, probably a Windows update
nuno1980
Ok. My "StarTech" DP to VGA adapter is connected between RTX 4090 with GeForce 572.xx driver and CRT monitor and rest ports of GPU card are emptied but no single issue running Win10 22H2.
PT vs PHT kernels - spp nrs
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
