octane option for material output is missing
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
jimho
For both new version of 29.13 and 29.14, in the material output node, the octane option is missing.
though for new project if choose "all" it may still work when using octane engine,
I believe this is a bug:
please imagine for old projects, it will be a big thing to change hundreds of materials...
Supermicro 4028GR TR2|Intel xeon E5 2697 V3| windows 10| revit 2019 |Titan V+ Quadro GV100+RTX 2080 Ti
linograndiotoy
Not a bug, just a change due to Blender's API limitations (Custom Build and Addon versions need to be unified as much as possible).
Just use the All option for Octane.
jimho
I see
it will convert to correct option automatically, so no need to worry about old projects,
Thank you.
jimho
Sorry, I found out why this issue is coming out.
when an old material has both evee or cycles output and octane output,
it will not converted correctly automatically, means the output option will leave as empty instead of "all".
So, my old projects cannot be corrected converted,
I hope this issue can be addressed, thanks.
linograndiotoy
This should be fixed already in 29.15.
If you have old scenes still presenting the issue, please send it to us (the simpler the better).
jimho
True as you said, in the 29.15 the issue is almost correct for most cases.
though I find myself in an embarrassed situation.
attached please find, when the old file is in the asset library, the issue remains...
if you open the problematic .blend file directly, it is fine, but if you insert the sofa from the asset library see the below image, the leather material lost...
002Sofa_rev00.blend
(23.84 MiB) Downloaded 143 times
Return to “Bug Reports”
