Chromatic Aberration Intensity ERROR!
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
tsykhra
Hello!
When I enable Octane Postprocess and trying to adjust Chromatic Aberration Intensity - an error occurs. It can be endless "Waiting for image...", or "ERROR! Check console for detailed error messages"
Terminal says:
Last Octane engine log entries:
compute device 0: copy size doesn't match destination image
I remember in simple scenes it worked but now it is not. Even on default cube. Maybe there's some settings i should check to eliminate this problem?
A. MacOS Sonoma 14.3.1
B. M3 Max
C. 48GB unified memory
F. 28.14
G. Blender octane build 4.0.2
linograndiotoy
Can you please show us your Post Process settings?
tsykhra
linograndiotoy wrote:Can you please show us your Post Process settings?
Just default settings. I'm enabling Octane Postprocess (Preview Mode) checkbox in viewport section and trying to add Chromatic Aberration intensity
linograndiotoy
Hard to know what's wrong without a scene showing the issue.
tsykhra
Just default cube scene
Here are 2 screenshorts - with and without Chromatic Aberrations
linograndiotoy
To have the perspective view Imager and PostProcess work, you need to enable the 2 checkboxes you can find on top of the Octane menu.
I notice you also have two additional ones that are unchecked. That may be the issue (those additional one are probably added by same addon you have installed - they're not part of the "default" Octane configuration).
tsykhra
I've disabled addon (Octane Tools by Andreas Resch) and 2 checkboxes on top are checked, but still no luck =(
linograndiotoy
My feeling is this may be a Mac specific issue.
tsykhra
Glad to see bug resolved in recent version of Octane!
linograndiotoy
Great!
Return to “Bug Reports”
