Hello!
When I enable Octane Postprocess and trying to adjust Chromatic Aberration Intensity - an error occurs. It can be endless "Waiting for image...", or "ERROR! Check console for detailed error messages"
Terminal says:
Last Octane engine log entries:
compute device 0: copy size doesn't match destination image
I remember in simple scenes it worked but now it is not. Even on default cube. Maybe there's some settings i should check to eliminate this problem?
A. MacOS Sonoma 14.3.1
B. M3 Max
C. 48GB unified memory
F. 28.14
G. Blender octane build 4.0.2
Chromatic Aberration Intensity ERROR!
C. RAM Capacity (i.e. 6 GB)
- linograndiotoy
Can you please show us your Post Process settings?
- linograndiotoy
Hard to know what's wrong without a scene showing the issue.
- linograndiotoy
To have the perspective view Imager and PostProcess work, you need to enable the 2 checkboxes you can find on top of the Octane menu.
I notice you also have two additional ones that are unchecked. That may be the issue (those additional one are probably added by same addon you have installed - they're not part of the "default" Octane configuration).
- linograndiotoy
My feeling is this may be a Mac specific issue.
