multiple colors on effector
Riot_Creative
hi, how do I achieve different colors on the effector in octane? I have a cloner of squares being driven by different type of effectors, I tried to use the color shader into the composite material. is there a way to specific which effectors is tied to the color shader?
please have a look at here, you don't need a composite material , you can use Fields to assign the color you want:
viewtopic.php?f=51&t=81807&p=425423&hil ... or#p425423
ciao,
Beppe
Riot_Creative
hi bepeg4d,
thanks for the tip and reply. Im not sure am I doing it right. I want to achieve having multiple effector/filed driving 1 single color on a cloner.
Each circle area represent 1 color each instead of random color
I have attached my c4d file
test c.zip
(214.87 KiB) Downloaded 67 times
you need to use an Instance Color node in the material, and assign the Cloner as Color Source:
test c_b.zip
(206.52 KiB) Downloaded 72 times
ciao,
Beppe
