Curvature node => Opacity=>shadows wrong
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
WoutTgh
plugging a curvature node into the opacity channel renders the object shadows as full opaque or at least the shadows are off. I tried the specular material, which has the fake shadows option and that seems to render correctly.
All the best,
Wout
WoutTgh
Played around with it some more, the fake shadow option does not render correctly either.
john_otoy
Hi WoutTgh,
This is a limitation in the Octane core. I asked one of our devs about this and he said it would require a lot more memory if we calculated dirt/curvature during shadow tracing.
WoutTgh
Hi John,
thanks for checking! Is the same limitation responsible for it not working on instances ?
john_otoy
If you're referring to the shadows generated by instances with curvature in opacity, then yes, the same limitation applies.
WoutTgh
No I meant the curvature node in general not working on instances.
john_otoy
That should work. Here is a test.
WoutTgh
ooh okedoke ! maybe something in my setup.. or Houdini... thanks !
Return to “Bug Reports”
