max slowly during rendering
samsue
I still have this annoying problem, it is impossible to use max while rendering
HHbomb
samsue
I've been saying this for weeks ... It's getting worse and worse to use Octane in "real time" together with 3ds
paride4331
wasn't this?
viewtopic.php?f=27&t=78459&p=404771#p404771
Regards
Paride
samsue
no ....
i remember last year when the render was on and i could keep working, changing materials etc... now in any kind of scene, everything just gets stuck
Just to remind I have 2x 3090 128Gb of ram ... I have already left the card that is connected to the monitor off for the rendering
paride4331
samsue wrote:no ....
Hi samsue,
would you try the Nvidia Studio drivers 472.12 uninstalling the previous drivers using DDU unistaller driver tool?
Regards
Paride
samsue
I am already using this drive and have installed it using DDU
paride4331
Hi samsue,
I can't reproduce your issue, could you share your scene in pm (with textures too)
3dsMax > File > archive
Regards
Paride
samsue
if you are rendering you can forget that octane also updates the mtsl and maps preview
neonZorglub
samsue wrote:if you are rendering you can forget that octane also updates the mtsl and maps preview
Hi samsue,
The slow max viewport should have been fixed in 12.07.
This was most visible on scenes with a large number of textures, as there was unnecessary updates.
There is still a slow UI issue from the main render settings dialog; It should be fixed in the next release.
Return to “Autodesk 3Ds Max”
