I just updated my Octane to the new version and ran into 2 problems:
1) Texture maps are not displayed correctly in Rhino viewport - Rhino uses roughness maps instead of diffuse textures. Is there an option to select the texture I want to use in the rhino viewport or is this just a current issue?
2) Renders come out different than before (light or colors) - is there any setting I should change by default?
						Octane 2021 issues after an update
Hi - can you please send me the scene that you posted the screenshots above from.
Hi Paul,
Thanks, here's a link to the scene https://we.tl/t-i6cbSAyuPS
Thanks - it is missing an IES file and some texturemap files - are you able to provide those please?lemonade wrote:Hi Paul,
Also - can you export the scene to .ORBX and provide that file too please.
Here's a link to the files and textures: https://we.tl/t-vhnguNaMNe
						Set the Kernel->White Light Spectrum to Legacy/Flat to render as per Octane 2020.
This is a plugin bug, and will be fixed in the next release.1) Texture maps are not displayed correctly in Rhino viewport - Rhino uses roughness maps instead of diffuse textures. Is there an option to select the texture I want to use in the rhino viewport or is this just a current issue?
