normal maps please ?
radiance
Hi guys,
I never used normal maps before from an artist point of view,
and to add support for them, i need some good working maps.
Can people provide some correct examples ?
(in both systems, eg Y+ and Z+ types) ?
You can post them either in 24bpp RGB png files,
or 48bpp or 96bpp RGB OpenEXR files.
Radiance
James
While I don't actually have any on me, I can point you to this one on CGtextures, http://www.cgtextures.com/texview.php?i ... 60b055702f
There are a fair few on there, though I don't know what the orientations of them are though...
Kubuntu 9.04 | Nvidia Gainward 9500 GT | Intel Core2 Quad 2.40 Ghz | 4 GB RAM
Chris
Here, i made a few for you. 24 bpp RGB png files. Y and X axis are different on all of them, check the file names and file comments for axis alignment.
Send me a mail or pm if you need more examples.
brick_diffuse
brick_diffuse
brick_normal_(Y-up)_(X-left)
brick_normal_(Y-up)_(X-right)
brick_normal_(Y-down)_(X-left)
brick_normal_(Y-down)_(X-right)
________________________________________________________
Win 7 64 | 1x GeForce GTX Titan | AMD Phenom II X6 3.20Ghz | 16GB
radiance
thanks a lot, i'm going to play with these while coding tomorrow. ;)
time for bed now, it's 2am already...
Radiance
Son Kim
radiance wrote:thanks a lot, i'm going to play with these while coding tomorrow. ;)
Radiance
I made this model awhile ago it contains a low poly mesh + textures + tangent space normal map + displacement map. The normal map was outputted from Mudbox using the Maya setting, it works in Modo renderer also. I know you don't need the displacement map..but you can use it for testing later on when u implement displacement map ;)
http://www.mediafire.com/download.php?dmgykyj1zmz
you can see a picture of the model in my website link.
edit: apparently there is no displacement map in this file, i'll update it with a displacement later.
Tugpsx
Here are a few I just converted
Grab ShaderMap Pro it's only $20 and does all that the others can. :)
Reliefs0116.rar
update in png format include Normal, Spec, Ambient, Displ, DUDV
(451.99 KiB) Downloaded 331 times
Tugpsx
Radiance
WOW! Awesome job on the bug. Great texturing!
radiance
Tugpsx wrote:Here are a few I just converted
thanks,
can you show me a rendered example so i have a reference ?
also, is this Y+ or Z+ type ?
Radiance
radiance
ok, i got it working.
seems to work well, i just need to add controls to tweak the amount.
here's the frog model rendered without and with normal maps.
both have diffuse and specular maps too.
Radiance
Hawker
you rock ...
