Bug of ORBX in standolne
Sub forum for bug reports
Moderator: ChrisHekman
HRHBG
Hellow~ I export scene into a ORBX file and I open it with OctaneStandalone, but one of a material element is wrong. When I open octaneGUI in Unreal, it will be normal. So, I should create octane material to solve this problem?
ChrisHekman
I think it would fix your issue yes.
However, I would like to check what is broken, could you share your material/model with me?
HRHBG
ChrisHekman wrote:I think it would fix your issue yes.
The model is Paragon kwang in Unreal market
ChrisHekman
Ah that makes sense. The paragon assets use complex materials with a lot of different node types. And Octane cannot support all types of nodes.
It looks like the emissive input covers the entire arm instead of just the jewel it is supposed to be on. i'll check it out if i can find the issue here.
Return to “Bug Reports”
