Phoenix FD infinite ocean
remKa
Hello guys,
I'm still having issues with the infinite ocean mesh setup with Phoenix FD, the definition of the ocean around
the liquid's grid is very very low whatever the number of particles simulated.
Thank you in advance !
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
nick73
Yes, same with me!!
Could we have a tutorial or a step by step instruction for this please?
Thank you!
coilbook
remKa wrote:Hello guys,
did you try ocean subdiv and displacement map?
remKa
Yes of course, ocean subdivision doesn't work whatever the value I set
It's (obviously) working fine on Vray next :)
remKa
There is also an issue with splashes particles, they are 5 times bigger than foam and mist particles..
I'm using Octane 2019.1.4 - 8.13
paride4331
Hi remKa,
set mesh scale in Octane particle WSM
Regards
Paride
remKa
Hi paride,
yes, this is what I did :)
But this is an issue to fix though, for the same geometry with same scaling values, foam / mist / splashes are not rendering with the same scale.
Did you check the infinite ocean issue ?
Thx
coilbook
remKa wrote:Yes of course, ocean subdivision doesn't work whatever the value I set
strange. I guess they broke something. We used it with octane 4 long time ago and it worked
RosKos
Hello!
I have a problem with endless ocean in Phoenix FD. For some reason, it is displayed in Octane only on a certain side. How do I fix this? I am going to render VR and this is a big problem at the moment.
paride4331
Hi RosKos,
did you active "pure ocean" in phonexix object > Rendering > Ocean
Regards
Paride
Return to “Autodesk 3Ds Max”
