Hello guys,
I'm still having issues with the infinite ocean mesh setup with Phoenix FD, the definition of the ocean around
the liquid's grid is very very low whatever the number of particles simulated.
Thank you in advance !
Phoenix FD infinite ocean
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
Yes of course, ocean subdivision doesn't work whatever the value I set
It's (obviously) working fine on Vray next
There is also an issue with splashes particles, they are 5 times bigger than foam and mist particles..
I'm using Octane 2019.1.4 - 8.13
- paride4331
Hi paride,
yes, this is what I did
But this is an issue to fix though, for the same geometry with same scaling values, foam / mist / splashes are not rendering with the same scale.
Did you check the infinite ocean issue ?
Thx
Thx
- paride4331
Hi RosKos,
did you active "pure ocean" in phonexix object > Rendering > Ocean
