Hairrender-bug in OC 2019.1.1 ?
useruser
hello,
i have no idea what is going wrong but it seems as if the octane-hairrender does interprets
the splines not correctly.
i tested it also with the native curve-mode in redshift- and it works as
expected:
Projectfile:
Octane_Hairrender_bug.zip
(215.98 KiB) Downloaded 145 times
thanks a lot in advance!
Workstation: Win 10 PRO 64 bit, 3,4 GHZ ,6-cores, 64 GB RAM , 4x RTX 2080 Ti
1. RenderSlave: Win 10 Pro 64 bit , 3x GTX 980Ti
2. RenderSlave: Win 10 Pro 64 bit 2x GTX 980 Ti
It's not a 2019.1.1 issue. Multi splines with "closed" option is not supported.
useruser
aoktar wrote:It's not a 2019.1.1 issue. Multi splines with "closed" option is not supported.
thanks ahmet,
do you know if this feature will be supported in the future?
thanks ahmet,
I'll try to add it, but not sure yet if possible
useruser
that would be great!
thanks a lot ahmet!
It seems like sorted, wait for next build
