Motion Vector passes are not working.
Version: 2018.1.3 / Octane Engine 17.9
Image renders out as flat grey.
If file exported to ORBX and rendered in stand alone, Motion Vector pass renders fine.
Other Issue:
My understanding is that for Motion Vector pass to work, Motion Blur must be enabled but does not render in final image. This is how it works in stand alone at least. However, the broken Motion Vector pass rendered in Octane Blender does show Motion Blur when there shouldn't be any. I am not sure if this is what is preventing the actual Motion Vectors from rendering?
Motion Vectors are also broken in Octane Blender v4 by the way.
Motion Vector Pass not working
C. RAM Capacity (i.e. 6 GB)
Objects that you want to have motion blur and motion vector pass need to have Mesh type set to "Movable proxy".
System – Windows 11
System – Windows 11
An example file with motion blur and vector pass.
- Attachments
- motion blur.blend
- (720.35 KiB) Downloaded 301 times
System – Windows 11
System – Windows 11
Thanks for your sample file J.C. It was very helpful, both for this post and my other one.
However, I am using a figure imported from Maximo which has armature animation, and this seems not to work with Motion Vectors even after changing the objects to Movable Proxy. Nor do I get any motion blur using the Internal setting MB.
Is there any specific set up required for getting Internal motion blur to work with armatures? I can render motion blur with armature animation using the Subframe setting, but Subframe doesn’t seem to work with Motion Vectors. See attached archive which contains both a blend and ORBX files.
NOTE that if exported to ORBX stand alone has no problem generating either the motion blur, or the Motion Vectors.
- Attachments
- MotionBlur-with-Armature.7z
- (14.26 MiB) Downloaded 286 times
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
Change mesh type to "Reshapable proxy". This will enable motion blur on deformable meshes.
System – Windows 11
System – Windows 11
