OctaneRender for Maya 4.02.1-13.33 [OBSOLETE]
Locked
Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya® Version 4
Maya® Version Requirements
This release will work with Maya® Versions 2016, 2016.5, 2017 and 2018 64-bit on Windows, Linux and OSX operating systems.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
  1. Go to https://home.otoy.com/render/octane-render/purchase/
  2. Select "Upgrade" in the top menu.
  3. Click on "UPGRADE NOW" next to "Upgrade existing licenses to OctaneRender 4".
  4. Select the licenses you want to upgrade and confirm.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Changelog and the installers for Octane Standalone 4.02.1 are here:
OctaneRender Standalone 4.02.1
Please read the new features implemented from Octane Standalone 4 version our blog post.
Changes since version 13.32:
  • Fixed vewport rendering efficiency issue.
  • Fixed a bug: light node's layer color did not work.
Windows DOWNLOAD
OctaneRender for Maya 4.02.1-13.33 Demo
Linux DOWNLOAD
MacOS DOWNLOAD
Subscription Studio Downloads
OctaneRender for Maya Studio 4.02.1-13.33 [Windows]
OctaneRender for Maya Studio 4.02.1-13.33 [Linux]
OctaneRender for Maya Studio 4.02.1-13.33 [MacOS]
Jolbertoquini
Hi Jim,
Please can we have a fix on the option "fit resolution gate" it was working before on OC3.06 plugs but now is not. we have weird result for viewport preview and export change "Fill" to "vertical" look quite fine but is missing some pixel on the ratio for the preview aswell for export to orbx as scene or alembic.
I think you did realize because in Maya default settings is Horizontal for basic cameras such Persp,side,top,front But when create a new camera is set at Fill.
here some previews.
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Locked
