Texture backing issue
TinkyFoo
Hello.
I try to bake texture from sss material. But there is an issue: places where two meshes intersects must be black, but in a texture it glows (has a very bright color).
For some reason i couldn't rebuild a mesh.
How could i correct this in octane?
what about the normals and uvs in that point?
You can check it via infoChannel kernel, or passes.
ciao Beppe
TinkyFoo
Well it is not a problem with uvs.
For example i have two spheres (i couldn't show my scene because nda).
Parts inside must be black, but it doesn't.
If i will try to render only one sphere it will be ok.
TinkyFoo
Well, i think it is somthing wrong with SSS.
But i don't get it.
When i bake AO-maps these places a totally black. It's help me to make some masks and destroy color in comositing. But it is not a panacea.
sorry but the image linkrd is not visible.
Please use the Upload attachment button.
Please also post a screenshot with infochannel geometry normals, and texture coordinates mode, thanks.
ciao Beppe
TinkyFoo
Hello.
I add some pictures.
Every place with intersection (or even close position) are glowing.
Under the grey stick its glowing
Surround objects is on
Normals
Normals
Texture pos
Texture pos
Surround  objects is off
