Phoenix ocean/water mesh and octane
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
coilbook
For some reason this new octane has problem rendering phoenix ocean mesh or any liquid mesh. One frame it renderers next one it does not. The liquid mesh is missing. Then it can appear and disappear.. Thanks
it has something to do with displacement phoenix texture. I am using 3.11.04 Nightly, Build ID: 2018100328568
scene link https://we.tl/t-80GdtMtHuv
please go to frame 1330 and see with rendering>displacement on and off
paride4331
coilbook wrote:For some reason this new octane has problem rendering phoenix ocean mesh or any liquid mesh. One frame it renderers next one it does not. The liquid mesh is missing. Then it can appear and disappear.. Thanks
Hi coilbook,
It seems 3.08 and 6.08 render in the same way your file.
Are you usign 3dsmax 2019? What about using 3dsMax 2018?
Regards
Paride
coilbook
Hi coilbook,
Regards
Paride
Hi Paride,
I am using 2018.4 3ds max. You said "It seems 3.08 and 6.08 render in the same way your file." is the problem related to textures? Were you able to reproduce the problem. It seems that when I xref the liquid grid the problem goes away. THanks
paride4331
Hi coilbook,
I have no idea because you did not share any texture with your file, so it's a little bit difficult to understand the scene if it is right while rendering.
Regards
Paride
coilbook
paride4331 wrote:Hi coilbook,
Regards
Paride
Hi Paridie
it is not about the textures. If you go to frame 1330 you will see there is no liquid mesh appearing. Thank you
paride4331
Hi coilbook,
this?
Regards
Paride
Return to “Bug Reports”
