Ok....so out of frustration with Carrara modifiers, or and the fact that Daz has abandoned  Carrara, I am trying to learn Blender.
 I have purchased the Blender Octane plugin.
My question:
Is it possible to get an Octane material from Carrara into Blender?
						Carrara to Blender
I don't know the Blender plugin but it should support importing materials from the local db material store.
The best way to move materials from carrara to the local db is to export your scene from carrara and load it into octane standalone.
Then you can save you materials to the local db and import them into blender.
Remember to save to Local DB, not Live DB. Local DB is stored on your hard drive, Live DB is stored in the cloud and will make your materials public.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
						In the node graph in the standalone, right click on the material you want to save and pick 'Save...'
In the save dialog change location to 'Local DB'.
Enter a category if you want, change its name, give it a description. Click Ok.
You should now see your material in the Local DB tab on the left most panel.
Note that you can save anything you want in local DB, not just materials. Note however, Blender may only support a limited set of imports. O4C only supports importing materials.
						Hi Rick,
I was there several times and tried alot other pieces of 3D software... but always came back to Carrara. What I can't do in Carrara, I do in Realflow or Houdini. I don't use Blender anymore, but I hope it works for you
Best wishes,
Thomas
Best wishes,
Thomas
http://www.thomas-schwenke.me
Houdini 20.5 || Win11 || i7 + RTX3080
