Carrara to Blender
Forums: Carrara to Blender
Carrara (Integrated Plugin developed by Sighman)
Carrara to Blender
Postby protovu » Thu Aug 02, 2018 12:22 am
protovu Thu Aug 02, 2018 12:22 am
Ok....so out of frustration with Carrara modifiers, or and the fact that Daz has abandoned Carrara, I am trying to learn Blender.
I have purchased the Blender Octane plugin.
My question:
Is it possible to get an Octane material from Carrara into Blender?
protovu
Re: Carrara to Blender
Postby Sighman » Sat Aug 04, 2018 2:01 pm
Sighman Sat Aug 04, 2018 2:01 pm
I don't know the Blender plugin but it should support importing materials from the local db material store.
The best way to move materials from carrara to the local db is to export your scene from carrara and load it into octane standalone.
Then you can save you materials to the local db and import them into blender.
Remember to save to Local DB, not Live DB. Local DB is stored on your hard drive, Live DB is stored in the cloud and will make your materials public.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Sighman
Postby protovu » Sat Aug 04, 2018 2:46 pm
protovu Sat Aug 04, 2018 2:46 pm
Thank you, Simon. Much appreciated.
But, it seems Carrara does not export a scene that Octane can open.
protovu
Postby Sighman » Sat Aug 04, 2018 3:03 pm
Sighman Sat Aug 04, 2018 3:03 pm
use export from the octane render viewport.
Sighman
Postby protovu » Sat Aug 04, 2018 5:12 pm
protovu Sat Aug 04, 2018 5:12 pm
the scene opens, I can select and copy, but pasting into the LDB is not working. The material gets pasted into the node graph editor.
protovu
Postby Sighman » Sun Aug 05, 2018 7:34 pm
Sighman Sun Aug 05, 2018 7:34 pm
In the node graph in the standalone, right click on the material you want to save and pick 'Save...'
In the save dialog change location to 'Local DB'.
Enter a category if you want, change its name, give it a description. Click Ok.
You should now see your material in the Local DB tab on the left most panel.
Note that you can save anything you want in local DB, not just materials. Note however, Blender may only support a limited set of imports. O4C only supports importing materials.
Sighman
Postby protovu » Sun Aug 05, 2018 8:16 pm
protovu Sun Aug 05, 2018 8:16 pm
Thank you, Simon.
Are you available for Octane for Blender questions?
protovu
Postby Sighman » Sun Aug 05, 2018 8:18 pm
Sighman Sun Aug 05, 2018 8:18 pm
I know nothing about Blender. Never used it.
Sighman
Postby protovu » Sun Aug 05, 2018 8:40 pm
protovu Sun Aug 05, 2018 8:40 pm
It is new to me, but as I find a little footing, it is very impressive. I am optimistic about it regarding projects. I though Octane would be a good inroad for me. It is definitely faster than
Cycles.
Modifiers alone are incredible.
protovu
Postby tschwenke » Fri Aug 24, 2018 8:27 pm
tschwenke Fri Aug 24, 2018 8:27 pm
Hi Rick,
I was there several times and tried alot other pieces of 3D software... but always came back to Carrara. What I can't do in Carrara, I do in Realflow or Houdini. I don't use Blender anymore, but I hope it works for you :)
Best wishes,
Thomas
http://www.thomas-schwenke.me
Houdini 18.5 || Win10 || i7 + 1 x RTX3080
tschwenke
Next
Return to Carrara
Sun Jun 16, 2024 1:07 am [ UTC ]
